Water Damage Fan Runs But No Heat
I'm sorry in advance for the length of this post, but I want to be concise. I am trying to sell a house "as is" but stated I would make sure the heat was working properly. Because the house is selling cheap I cannot put too much $ into unit. The house has been unoccupied since last fall. Prior to that there was a broken pipe that caused the crawlspace to flood affecting the airhandler in the crawlspace. The water was evacuated and a service tech came out to look at the unit. Unit checked OK and was in service about 2 months before problems started. Heat would come on but would not shut off. Had to turn off breaker to get heat to shutdown. Turn on breaker and would work a few days. Tech came out and replaced transformer. Unit worked for a week then the fan would not cutoff and the heat stopped working. Tech came out and replaced sequencer. Worked for a day then the same problem. The sequencer was pulled from an unistalled unit in my garage that is a 1.5 ton 10seer upflow Comfortmaker and placed in the 2.5 ton 10seer horizontal flow airhandler (by Tech's OK). With disconnected power I went under the house and cleaned all the contacts of any rust and corrosion with contact cleaner and a softwire brush. The only parts that appeared affected by the water were toward the bottom of the unit. That included the transformer (which was replaced) and what looks like a switched replay. The relay is in bad shape as are the paddle connections, but nothing looks shorted or burnt, just rust causing poor contacts. I am going to replace the paddle conns and the relay, but the man/model# tag is missing. The old relay was a completely enclosed small black box with five connections having 4 occupied with wires. I documented the connections and tried to find a replacement. While getting a new part a Tech suggested a repacement (White-Rodgers 90-340) that has many more connections and an exposed coil. I disassembled the old part and have a good idea of how the switch is controlled, but am unsure of how the wires should reconnect to the new part. Both parts have numbered terminals, but I am unsure if this numbering system is universal and I can just reconnect the wires to the corresponding number. I also wanted advice on whether or not I should put the old sequencer back in seeing how it did not solve the problem and any other recommended service I can do while the power is down and I'm under the house. Everything I own breaks so I do have experience reparing things. This past year I did fix my Trane Compressor unit just using some common sense and little research. Thanks for any help you can provide and in exchange I'll give you some tips on what not to do when tiling floors.
Thanks, Mike |
Re: Water Damage Fan Runs But No Heat
always install fuses on both legs of t-former. these usually dont go bad. probably have short in system. look at the back of the circuit board.
NICKTECH
unless you have electric heat, there aren't any "sequencers" in a furnace. how old is the furnace and what is the model #. like i've posted before, in a furnace with a computer module moisture is like preforming a labotamy. moisture will affect the modules in different ways. it kind of sounds like you are working with a r8222 general purpose relay.(i think) there should be schematic printed on the face of the relay with the terminals. let me know what you have or maybe send a pic of the controls and i'll try to help you out.
#4 | |
Re: Water Damage Fan Runs But No HeatQuote:
| Hot Water Heat Pump | wstokes | HVAC | 0 | 04-10-2007 12:51 AM |
| using attic to heat your water? | rhinoguy | Plumbing | 8 | 02-25-2007 08:04 PM |
| water heats water but doesnt circulate heat in baseboards | geno49 | HVAC | 4 | 10-17-2006 08:38 AM |
| Water Damage | Dusty | Remodeling | 4 | 01-29-2006 10:10 PM |
| Heat Exchanger Inspection Methods | MechAcc | HVAC | 3 | 04-14-2005 04:38 PM |
