Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 09-09-2005, 12:38 AM   #1
Remodeler
MinConst's Avatar
Want to setup a HWH as a boiler for heat
I would like some info on using a hot water tank as a boiler to heat our basement. What is needed and some design help. I think it fairly simple but never dealt with boilers of any type myself. I had this type of heat in a shop I rented a few years back and it worked great.
Thanks guys and gals.
Paul
Minichillo's Construction
Website One Man Shop
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 09-09-2005, 04:54 AM   #2
Bjd
Trade:
Are you talking about adding a heater, or using an existing tank?
BJD
Bjd is offline   Reply With Quote
Old 09-09-2005, 06:29 AM   #3
Remodeler
MinConst's Avatar
I was planning on adding another tank. I don't want to comprimise our hot water. I'm open for suggestions. Using our existing would certainly lower the costs. But as I said I don't want to loose hw for normal use.
Paul
Old 09-09-2005, 08:03 AM   #4
How many BTU's are you going to need to keep the basement heated? Why not just get a small boiler?? Just curious.
TimNJ is offline   Reply With Quote
Old 09-09-2005, 03:46 PM   #5
Remodeler
MinConst's Avatar
Tim,
I have no idea on the BTUs, I'm a carpenter. Seriuosly though I figure a HWH would be less expensive and possibly smaller. How much is a small boiler cost anyway?
Thanks
Paul
Old 09-09-2005, 06:28 PM   #6
Trade: plumbing and heating
There are a lot of problems that can be associated with a water heater being converted to a boiler.
A water heater would not recover fast enough and therefore would be ineffecient.You are heating too big of a body of water for a heater to recover. Which is why boilers are in sections for more suface heating/effeciency and recovery! Baseboard heat is sized and designed for 180 degree water. So, the thought of using you're existing heater because you might compromise you're supply wouldn't be the biggest concern.. It would be the safety of you're family being vulnerable to such hot and dangerous temperatures!!!
The upfront costs of using a water heater look appealling but that is where the good stops! I would recommend you get a heat loss done for the area you wish to heat and then look at you're boiler options. There are a lot of small boilers out there ie. backpacks etc.. Some of these backpacks are tankless water heaters that might work depending on conditions, but I personally would stay away from tank type water heaters.
plumguy is offline   Reply With Quote
Old 09-09-2005, 08:01 PM   #7
Remodeler
MinConst's Avatar
Plumguy,
That is great information I appreciate it. I will look further into what you recommend.
Paul
Painting Exterior EIFS Home / Spray Gun Setup plazaman Painting & Finish Work 9 06-18-2007 10:03 PM
boiler plumbing question 72chevy4x4 HVAC 2 05-06-2007 07:26 PM
New Trailer Toungue Setup plazaman Welding & Steel Trades 7 03-01-2007 01:29 PM
boiler conversion ofourcobra Plumbing 1 12-28-2006 07:46 AM
hot water boiler, burners shutting off r2d2 HVAC 4 11-23-2006 12:08 PM
