Venting 80% Furnace & Water Heater
Old 11-11-2003, 12:26 AM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Is there any problem with venting an 80% Trane 80XL furnace on the same vent as a water heater? Is Type-B piping required? The furnace is at the end of the vent. In this case, won't the exhaust from the furnace vent through the water heater (the furnace uses an inducer for venting).
Old 11-11-2003, 08:40 AM   #2
General Contractor
hatchet's Avatar
Re: Venting 80% Furnace & Water Heater
Off the top of my head - I'm pretty sure this is ok. I've seen this in many many new houses. I don't believe a B Vent is necessary unless there is no outside air for combustion air. Then again I think UBC requires outside combustion air anyway - one duct high and one duct low.
Rich
WIT Construction Co.
Superior MT Contractor
hatchet is offline
Old 12-13-2003, 09:08 AM   #3
Unregistered
Guest
Posts: n/a
Old 12-19-2003, 06:42 AM   #4
Bjd's Avatar
I know around here that the two cannot be inter connected, as one unit is power vented and could possible send exhaust fumes into the other unit in the event of a blocked condition.
They require the two to be exhausted to seprate flues.
Bernie
Bjd is offline
Old 01-04-2004, 05:53 PM   #5
Unregistered
Guest
Posts: n/a
ohio new building has 80% and hw heaters connected to b vent. if it an old chimney..needs flue liner since 80% has alot of moisture to expel. also want fresh air ..
Old 02-10-2004, 01:34 PM   #6
Unregistered
Guest
Posts: n/a
Question
Along this topic.....I am buying a house that's been split into two apartments. One apartment has a new 80% furnace. The second apartment has an old gravity furnace that I am replacing with a 90% furnace. Both of the existing furnaces vent into the masonry chimney. I don't think that there is a condensation problem now since the gravity exhaust is so warm. However, when I install the 90% furnace, what is my best venting solution? Stainless Steel flue liner? Or can the 80% and 90% both go out a PVC vent?
Old 02-10-2004, 07:26 PM   #7
Steve Wiggins's Avatar
Induced combustion motor on a gas furnace pulls air through the heat exchanger and thats about it. It does not force air all the way out the flue pipe (or its not designed to anyway). So yes it is ok (according to code) to include the water heater in the same venting system but personally I wouldn't do it. When flue gasses get too cool they can condense on the inside of the flue pipe and cause this:
Steve Wiggins is offline
Old 02-11-2004, 06:13 AM   #8
Bjd's Avatar
Hey where is the cleanout on that, up here we cannot connect to the base like that we have to have a tee with a cleanout at the base.
Bernie
Bjd is offline
Gas water heater with timer on it? rhinoguy Plumbing 1 06-10-2010 11:11 AM
Is it safe to drink water from Hot water Heater? robertc65 Plumbing 14 02-04-2007 12:11 PM
Water heater Help tzzzz216 Plumbing 10 11-22-2006 03:30 PM
Venting of Furnace and Water Heater novendeh HVAC 1 04-09-2006 09:46 AM
Water Heater Venting rakes9720 HVAC 4 01-25-2006 07:28 PM
