Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 12-19-2007, 12:34 AM   #1
Trade: residential remodeling
unique installation
i had a goodman unit installed a year ago. the inside unit is a 3 ton with a gas heater. the outside unit is a centurion and is a 2 1/2ton.
i was told that it would run more effeciently that way. well......... it does, my bill in the heat of summer in fla. august is no more than $193 and i have leaking wooden windows and no insulation on my exterior walls. i am just wondering of other opinions on this matter. and no i have had no problems with the unit or installation.
remodeling joe is offline   Reply With Quote
Old 12-19-2007, 01:03 AM   #2
Teetorbilt's Avatar
Damn! I thought that a unique installation is where you have to take the sucker apart and reconfigure it.
I work marine and this is not unusual although we try to avoid it as much as possible. Chilled water units are always tinkertoys.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 12-22-2007, 11:13 PM   #3
what!!???? man,, i didn't get what you were trying to say. i'd just like a clear response to my curiousity about the installation.
Old 12-23-2007, 12:52 PM   #4
Thom
thom's Avatar
Manufacturers work their butts off to get these systems to work well and be energy efficient. They spend a lot on engineering and testing. They work hard to do this because efficiency costs money and the government demands it.
Now you're saying that some guy who has done no scientific testing, probably not an engineer, tells you mixing units will run more efficiently. Then you say you believed him. Did you ask what research he had done?
You would likely have done better by matching the inside and outside units.
thom is offline   Reply With Quote
Old 12-23-2007, 02:20 PM   #5
HVAC Old Timer
HeatPro's Avatar
Trade: HVAC
I guess Joe is saying that the 3-ton indoor coil is being used with a 2-1/2 ton outdoor unit. That is, in fact, what Goodman recommends to get a higher SEER rating, a larger indoor coil. Many manufacturers achieve better final ratings by using larger indoor coils and especially so with a TEV. So there is nothing unusual about it and it works as tested.
HeatPro is offline   Reply With Quote
Old 12-23-2007, 07:50 PM   #6
hey heatpro i sure do appreciate you statement, i feel much better now. although i never had a problem with the system and installation, it just always stuck in the back of my head. thanks again
Last edited by remodeling joe; 12-23-2007 at 07:51 PM. Reason: wrong name addressed
Hardie Plank (per square rate of installation) jimetime Windows, Siding and Doors 26 03-04-2009 04:41 PM
Exterior Door Installation BoydS Remodeling 59 02-20-2009 04:54 PM
flu liner installation Big Dog Dan Masonry 2 08-21-2007 08:42 AM
Engineered Floor Installation BoydS Flooring 4 02-17-2007 07:18 PM
Installation costs? dennyc Carpentry 2 06-10-2006 10:09 AM
