Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
View Poll Results: To trap or not trap condensate drain?
Trap 9 81.82%
Don't trap 0 0%
Doesn't really matter 1 9.09%
I dunno 1 9.09%
Voters: 11. You may not vote on this poll
Old 07-17-2009, 07:31 PM   #1
Trade: contracts/negotiations
To trap or not to trap condensate drain on a package unit?
On the same roof top, I see some units with a straight reversed L pipe and some units with traps.
The water in trap keeps the indoor air from flowing out, but water always remains at the level of the pipe and keeps stagnant water in the condensate pan and promote corrosion...
Electric_Light is offline   Reply With Quote
Old 07-18-2009, 07:28 PM   #2
NICKTECH
NickTech's Avatar
Trade:
Send a message via AIM to NickTech Send a message via MSN to NickTech
on package systems the blower is in front of the coil, placing the coil and drain pan under a negative pressure. the suction will draw outside air in through the drain not only adding to the load, but more importantly draws a mass of air through the drain pulling the drain water away. this allows for the pan to overflow. installing a trap will block the air from pulling the drain water away from the drain. as long as condensate is being removed then the water in the trap wont be stagnant.
NickTech is offline   Reply With Quote
Old 07-19-2009, 08:23 AM   #3
Trade: HVAC Service Technician --RSES CM-- NATE Certified
Condensate Trap Articles
Here are some links to articles on condensate traps. Some will download pdf files. The articles point out problems with incorrect trapping.
Condensate Traps Jan 1, 2001 HPAC Engineering
Web Site video page for Cost Gard Traps on different trap problems Go to the bottom of the page for the videos. Cost Gard is the drain trap specified by WalMart and Walgreen Stores. An expensive drain to purchase but will pay for itself by preventing water damage. The last couple of videos show the Cost Gard installed.
Condensate Trapping Don’t Get Caught in a Trap of Your Own.
ASHI Reporter article “Let’s Concentrate on Condensate”
MechAcc is offline   Reply With Quote
Old 07-19-2009, 04:18 PM   #4
senior member
Trade: class A gas industrial
Nicktech is bang on!
trout lake is offline   Reply With Quote
Old 07-20-2009, 01:11 PM   #5
coolmen's Avatar
Trade: hvac
thats what I was gonna say)
coolmen is offline   Reply With Quote
Old 07-22-2009, 10:02 PM   #6
sparky_123's Avatar
Trade: hvac/ electrical
trap is a must, i like to put a lttle bleach in drain pan once a year keeps crap from building up
sparky_123 is offline   Reply With Quote
Old 07-25-2009, 01:38 PM   #7
Trade: H.v.a.c.
Trapping is the easy part. It's going into the crawl space to make sure that the condensate line is graded right that gets neglected. Frequently when under the house, I see that the condensate run is messed up.
flashheatingand is offline   Reply With Quote
Tags
condensate, package unit, pipe trap
24,000 BTU Ruud package unit, 40oz vs 70oz R-22 Electric_Light HVAC 6 07-18-2009 11:31 PM
Help on Armstrong Air Package Unit curranelectric HVAC 4 01-09-2009 07:43 PM
How close to the drain should the trap be? drb9 Plumbing 17 11-04-2008 07:59 PM
odd Goodman package unit problem airwick HVAC 3 07-17-2008 10:36 PM
Coil height for condensate drain trap davidchomes HVAC 10 09-10-2007 09:36 PM
