Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 03-01-2004, 11:30 AM   #1
Unregistered
Guest
Trade:
Posts: n/a
Trane versus American Standard Central Air
I am building a custom home in Southwest Florida. The builder tells me that American Standard and Trane are the same companies. I see that Trane is owned by American Standard. Are the units similar. Is Trane a higher end division. Would I be better off going with one over the other. I am not getting the super efficint models, just the 12 to 14 seer units.
Any comments?
Thanks
Old 03-01-2004, 12:46 PM   #2
Unregistered
Guest
Trade:
Posts: n/a
As long as it has the "Climatuff" reciprocating compressor you will be fine. It doesn't matter if you have to go with the 10 SEER to get it either. You will know it is a climatuff if it is orange.
Also request a hard start kit and a TXV. If you get these 3 things properly charged with a good duct system everything will last full life span (30yrs+). Be sure to have it serviced every season so it can be washed and the capacitors checked. This unit's compressor has a built in accumulator and a trickle feed heater that is powered by an extra capacitor.
It saying Trane or American Standard is only the body style. What's under the hood is what really counts!
Old 05-03-2008, 08:36 PM   #3
Duh.........
......Id insist on a model with a SCROLL.
mermaid is offline   Reply With Quote
Old 05-07-2008, 06:52 AM   #4
Trade: HVAC contractor
Just make sure it is not Ameristar that is the builders grade version of american standard besides that they are identical.
awtr3y is offline   Reply With Quote
Old 05-08-2008, 05:51 PM   #5
Trade: H.v.a.c.
i agree
Brands are pretty similar when comparing apples to apples. As Mermaid said, a scroll compressor is a little better (quieter and slightly better efficiency)
flashheatingand is offline   Reply With Quote
New OSHA standard OsNap Health & Safety 2 12-06-2006 01:02 AM
American Standard Whirlpool pump bad? nobody Plumbing 5 11-07-2006 10:28 PM
American Standard Champion toilet Steampiper Plumbing 8 07-21-2006 03:57 PM
American Standard or Carrier? Bigvree HVAC 4 02-03-2006 08:10 PM
Trane or American Standard? EdBickford HVAC 4 09-07-2005 07:16 PM
