Trane 12 Ton Roof Top HELLLLLLLLP
Old 02-08-2008, 08:40 PM   #1
TNHVAC's Avatar
Trade: HVAC
I have been working for myself for 2+ years, mostly on residential units, I recently got a contract with a factory & have completed several jobs with no problems. NOW I'M in over my head,this darn thing will run between 5 & 6 minutes then stop & lock out. (Gas Heat) I have robbed a 2nd unit that has at some point had a internal explosion & no longer in use. Changed out both boards, etc. still same thing. crack in heat exchanger maybe? This is the 1st unit I have worked on with a negative gas pressure & combustion blower motor instead of induction motor. Thanks for any advice.
TNHVAC is offline
Old 02-09-2008, 10:20 AM   #2
az-guy's Avatar
Trade: hvac
Re: Trane 12 Ton Roof Top HELLLLLLLLP
check the flame sensor, is there a flash code for self troubleshoting
az-guy is offline
Old 02-09-2008, 09:33 PM   #3
HVAC Old Timer
HeatPro's Avatar
Trade: HVAC
Perhaps you can find a make and model. A negative gas pressure is usually done with an induction blower. A power burner usually feeds a negative chimney draft and chamber.
HeatPro is offline
Old 02-10-2008, 10:22 AM   #4
briandurussel's Avatar
Trade: Belle Mechanical
Can you go into test mode by leaving your jumpers on teminals 1 and 2 and pulling them off when the unit goes into its heating stage? How long will it run then? You can single out a control problem that way.
Make sure all of your safeties are made and auxillaries are staying made. You may need to take an hour or so to check them but you have to make sure.
Check the board('s) look for any shorts or water damage.
If it is a "power" burner make sure your screen is clean and your tubes do not have any cracks at the bottoms (heat exchangers).
Definitly check your pos-neg pressure tubes to make sure they are not filthy.
Had a unit do the same thing and found an Auxillary faulty, it was located behind the main 3 pole 480 volt main breaker on the unit.
briandurussel is offline
Old 02-11-2008, 08:21 PM   #5
TNHVAC's Avatar
Trade: HVAC
Thanks for the advice,found the problem today the unit was heating some new offices with relocated then removed & replaced T/stat drywall guys ran a screw into the wiring D--- thing acted crazy as -ell would call the lady in the office to turn on & off up/down work for awhile lose call for heat, then start up again. Thanks again
TNHVAC is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
