Time For An HVAC Quiz
Old 04-13-2009, 10:17 AM   #21
hvaclover's Avatar
Trade: hvac
Re: Time For An HVAC Quiz
Originally Posted by NickTech View Post
min evac. level mandated by epa on vacuum pumps are 500 microns, even if you could pull down to 200 microns the vacuum would only be 29.91"hg. vacuum pump oil has a boiling point under atmospheric conditions between 721-1004 deg f,and will not vaporize at that point under that vacuum.
The oil does not evaporate. It degases.
hvaclover is offline
Old 04-29-2009, 06:32 PM   #22
beecoolinc's Avatar
Trade: HVACR
Even Even A!
beecoolinc is offline
Old 05-06-2009, 02:22 AM   #23
forster's Avatar
Trade: HVAC Engineering and Sheet Metal Fabrication
I am inclined to agree with NickTech, since he does actually back up his answer with a source.
Does it count as cheating on the quiz when I look at other people's answers?
forster is offline
Old 05-06-2009, 06:41 AM   #24
beenthere's Avatar
Trade: HVAC
section 608 of the federal clean air act, under prescrided evac. rate. (EPA.gov)
I think you'll find that is not a regulation.
But a recomendation.
beenthere is offline
Old 09-01-2009, 07:28 PM   #25
cralx2k's Avatar
Trade: I'm a HVAC student.
“Evacuate
the system to below 200 microns.” This should not
be considered. Note that the word “system” is used
here, because it is possible to evacuate piping or
some component other than the compressor to below
this level. Refrigeration oil has a vapor pressure and,
by going below 200 microns, you will degas particles
of the refrigeration oil. Be aware that if you change
the makeup of the oil, it will no longer be a true
lubricating oil.
Source - jbind.com/tools/userfiles/file/Deep_Vacuum.pdf
cralx2k is offline
Old 09-01-2009, 07:59 PM   #26
beenthere's Avatar
Trade: HVAC
Check the original cpyright date on that article, or the sourse for that article.
Old 09-01-2009, 08:03 PM   #27
hvaclover's Avatar
Trade: hvac
Originally Posted by cralx2k View Post
“Evacuate
lubricating oil.
go to the principal's office. You peeked at the test answers on my desk
The Following User Says Thank You to hvaclover For This Useful Post:
cralx2k (09-01-2009)
Long time reader first time blogger! bigsmooth Introductions 7 02-25-2009 10:47 PM
Long time listener, first time caller BakersDozen Introductions 15 02-17-2009 09:56 PM
Contractor Talk & Time Management Mud Master General Discussion 30 02-10-2009 09:22 PM
What takes 0.15% of your time...... KentWhitten General Discussion 12 02-07-2009 05:24 PM
Need some HVAC opinions and help Mike B HVAC 5 09-07-2008 07:16 PM
