Time For An HVAC Quiz
Old 04-07-2009, 09:34 PM   #1
hvaclover's Avatar
Trade: hvac
Ques: Evacuation to well below 200 microns is:
A] Desirable and even even mandatory to remove all moisture.
B]The lowest level system should be pumped down to because ..(describe the changes that would be detrimental to the sealed system)
C] What is an evacuation?
Winner gets a No-Prize.
Just slow, not stupid.
hvaclover is offline
Old 04-08-2009, 01:33 AM   #2
flashheatingand's Avatar
Trade: H.v.a.c.
Re: Time For An HVAC Quiz
B. Because you have several other calls waiting and it's time to get to the next job. Seriously, I don't have an answer to detrimental changes. Only thing I can guess it has to do with charging the system and some type of chemical reaction?
flashheatingand is offline
Old 04-08-2009, 01:52 AM   #3
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extrordinaire
A. is correct.
B. would cause a total vacuum which is an impossibility thereby causing untold catastrophic consequences to the very fabric of the universe itself, tearing it asunder and plunging us all into a quantum world of black holes and uncharming quarks.
C. An evacuation is what my bowels do.
Andy.
ScipioAfricanus is offline
Old 04-08-2009, 02:12 AM   #4
Handle It!
MALCO.New.York's Avatar
A Dipshiiit quiz posed by a Dipshiiit quizzer?
Ultimate Wisdom---------
MALCO.New.York is offline
Old 04-08-2009, 08:27 AM   #5
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
no, 500 microns (29.9"hg) is not only the manditory rate, but it is the pressure at with water will boil at -12 deg f.
anything lower will not cause any problems but just a waste of time. it is not possible to over evacuate a system!
EPA mandates all vacuum pumps pull down to min. of 500 microns.
evacuation is the dehydration of a system by the use of a vacuum pump to remove water and water vapor by dropping the boiling point.
i'm not only smart, im good looking too!..............where is my "no-prize"
NickTech is offline
Old 04-08-2009, 09:42 AM   #6
hvaclover's Avatar
Trade: hvac
Gotta answer the whole question.
Old 04-08-2009, 09:45 AM   #7
hvaclover's Avatar
Trade: hvac
Originally Posted by ScipioAfricanus View Post
A. is correct.
Andy.
No. Your bowels void, not evacuate. There is no correlation with quantum mechanics.
Old 04-08-2009, 09:55 AM   #8
hvaclover's Avatar
Trade: hvac
I know that interview by heart and love the hell out of it.
I been funin' 'ya this time.
I am a HUGE Bruce Lee fan. I just threw some **** at you only in fun cause I studied Okinawan
No more wise cracks about Bruce.I promise.
Now let's go harass the the Korean Stylists
Old 04-08-2009, 10:01 AM   #9
hvaclover's Avatar
Trade: hvac
You failed to make a choice.
Si have to say your answer is incorrect.
This is not a crank quiz. The question comes from leading hvac source and a nationally recognized hvac mfg.
Old 04-08-2009, 10:02 AM   #10
hvaclover's Avatar
Trade: hvac
step up and give it a shot...
Old 04-08-2009, 10:27 AM   #11
Remodeling GC
kevjob's Avatar
you have a test coming up?
kevjob is offline
Old 04-08-2009, 01:29 PM   #12
NICKTECH
NickTech's Avatar
A. False
B. 500 micron (29.9" hg)/ no detrement-overevacuation is impossible
C. evacuation is the dehydration of a system by the use of a vacuum pump to remove water and water vapor by dropping the boiling point.
Well if i'm incorrect then the thousands of students i've trained are incorrect as well as the EPA and RSES (my sources)
NickTech is offline
Old 04-08-2009, 02:31 PM   #13
hvaclover's Avatar
Trade: hvac
A. False
you may only pick one.
your response "no detriment-over evacuation is impossible" is not accurate.
Old 04-08-2009, 08:57 PM   #14
Trade: H.v.a.c.
Ok, I think I have the answer to the question about why one doesn't want to evacuate way too low.
The reason, when approaching the perfect vaccum level, you will boil the refrigerant oil which will result in vapors in the line.
I fancy myself a guru of such matters.
Honestly, I just googled evacuating refrigerant lines, and I read something in regards to the vapor.
Old 04-08-2009, 09:06 PM   #15
hvaclover's Avatar
Trade: hvac
So does Fat Eddy...
Old 04-12-2009, 07:14 AM   #16
oldguy2's Avatar
Trade: hvac
i choose D: impossible
a perfect vacuum is only possible in outer space
like the space between my ears
oldguy2 is offline
Old 04-12-2009, 08:27 AM   #17
beenthere's Avatar
Trade: HVAC
Wha section is that mandate in.
beenthere is offline
Old 04-12-2009, 08:30 AM   #18
beenthere's Avatar
Trade: HVAC
Even outer space is not a perfect vacuum.
Some inner spaces, may be though.
Old 04-13-2009, 07:51 AM   #19
NICKTECH
NickTech's Avatar
min evac. level mandated by epa on vacuum pumps are 500 microns, even if you could pull down to 200 microns the vacuum would only be 29.91"hg. vacuum pump oil has a boiling point under atmospheric conditions between 721-1004 deg f,and will not vaporize at that point under that vacuum.
NickTech is offline
Old 04-13-2009, 07:53 AM   #20
NICKTECH
NickTech's Avatar
section 608 of the federal clean air act, under prescrided evac. rate. (EPA.gov)
NickTech is offline
Long time reader first time blogger! bigsmooth Introductions 7 02-25-2009 10:47 PM
Long time listener, first time caller BakersDozen Introductions 15 02-17-2009 09:56 PM
Contractor Talk & Time Management Mud Master General Discussion 30 02-10-2009 09:22 PM
What takes 0.15% of your time...... KentWhitten General Discussion 12 02-07-2009 05:24 PM
Need some HVAC opinions and help Mike B HVAC 5 09-07-2008 07:16 PM
