I've been trying to find a small one for my garage. During my research, here's what I've found out about pellets:
Pellets burn very cleanly and create only a layer of fine fly-ash as a byproduct of combustion. The grade of pellet fuel affects the performance and ash output. Premium grade pellets produce less than one percent ash content, while standard or low grade pellets produce a range from two to four percent ash. Users should be aware of the extra maintenance required with a lower grade pellet, and that inconsistent wood quality can cause serious effects to the electronic machinery over a short period of time.
Of course, there are multiple types of pellets; corn, wheat, etc. You need to make sure your stove will handle what you burn. Geographical location determines what's most readily available in your area (eg. Iowa, corn would be plentiful).
"If you're good at something, never do it for free."
