Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 03-02-2009, 08:05 PM   #1
Trade: Flooring
Thermostat Wiring Help
Hey Guys:
I am a flooring contractor and I am looking for some thermostat wiring help. I have a rental property where i evicted a tenant and they did some major damage including ripping off the existing thermostat off the wall.
I have an electric air handler (Lennox CB18). This is a blower coil unit and it has A.C. I know that i have a 5 wire installation. On top of the air handler this is what wires go to what letters. You see Blue, Orange, White, & Yellow. Coming out of the wall is Red, Blue, Orange, Black, & White. That means above the air handler the black wires are tied together, as well as the red wire. The yellow wire does not go to the thermostat.
I bought a Honeywell, RTH110B. The link to the manual that shows the wiring schedule for 5 wire is : http://www.honeywellcentral.com/ssi/...ers-manual.pdf
I am not sure what wire to put where. According to the manual i need to remove the little red jumper wire.
Any help would be appreciated. Thanks.
-Dave
GoodHouse is offline   Reply With Quote
Old 03-03-2009, 08:37 AM   #2
Trade: HVAC
You need to look on the unit schematic and see what the "3" terminal energizes. The other wires will go to the same terminals (R, W1, G) on the new thermostat.
The Veto toolbag, the Louis Viton of tool transport. The official toolbag of rich guys.
BigMikeB is offline   Reply With Quote
Old 03-05-2009, 05:47 PM   #3
HVAC Tech, NATE certified
Trade: Hvac technician. Economy Heating, Pittsbur
Here is a diagram that should help. But remember sometimes people splice and change wire colors, so visualy check to make sure that the wire is the same color all the way through.
Best line from a customer "you here for the tune-up? the tank of 22 is in the shed, let me know if you need more."
Verbal is offline   Reply With Quote
'Quick Wiring' question nadonailer Electrical 85 05-31-2009 08:57 AM
Thermostat question kbsparky HVAC 7 03-08-2009 11:31 AM
Can I split thermostat wire??? Jambruins HVAC 5 01-13-2009 06:29 PM
Single pole vs. double pole thermostat dforeid Electrical 2 10-23-2008 09:42 PM
Thermostat Wiring daviar HVAC 1 06-29-2008 05:15 PM
