Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 04-04-2005, 09:43 PM   #1
Trade:
thermostat wiring
I'm trying to install a new thermostat in a home. It controlls both heating and AC. I'm having trouble getting the wiring correct. There's a black wire that I'm not sure of. If I connect it to the RC connection the fan won't shut off in the test program of the thermostat. Do I have to jump R and RC? Very confused. Anyone got the correct way to wire it?
zooter7878 is offline   Reply With Quote
Old 04-04-2005, 10:38 PM   #2
Teetorbilt's Avatar
Doc will be along, hang tight.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 04-05-2005, 06:28 AM   #3
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
How many wires do you have total? What is the model of the thermostat? Where was the black wire hooked at on the old stat? We can get you back up and running with just a little more info.
HVAC Doc is offline   Reply With Quote
Old 04-06-2005, 08:37 PM   #4
Trade:
7 wires
Honeywell T8600D
The black wire was hooked to the X connection on the old thermostat. Thank you for any help.
Old 04-06-2005, 09:05 PM   #5
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
7 wires
Honeywell T8600D
What was the Brand and model of old stat then we can tell you what X should hook to on your T8600D.
Edit: Got to looking at HW contractors site and if you have a single transformer system (one mounted in furnace typically) then all X was normally was a common. You can verify this by looking in your furnace/airhandler and seeing what the black wire hooks to inside. If all it was was a common, according to Honeywells Techlit, you should be able to eliminate that and just jumper your R/RC terminals and it work ok.
Old 04-07-2005, 08:09 PM   #6
NICKTECH
NickTech's Avatar
Trade:
Send a message via AIM to NickTech Send a message via MSN to NickTech
http://hbctechlit.honeywell.com/tech...0s/60-2246.pdf
check out page 4. what was the old t-stat model?
NickTech is offline   Reply With Quote
Old 04-10-2005, 08:17 AM   #7
Trade:
Thanks for the help.
Wireless thermostat Speedy Petey Electrical 5 02-22-2007 04:30 PM
inground pool wiring diagram sparklito Electrical 3 01-13-2007 01:45 PM
Feed back Please ,water heater Thermostat tzzzz216 Plumbing 4 11-11-2006 02:42 PM
New Thermostat for American Standard Supmac HVAC 2 12-05-2005 07:16 PM
Garage - Protecting wiring installation eastment Electrical 1 11-22-2005 02:52 PM
