Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 02-02-2007, 11:46 PM   #1
Trade: hvac
Smile thermostat question
I have a question about t stats:
on a typical rheem heat pump in heating mode( the o/b -rv is energized)(y is energized)(White wire goes to aux and is jumped to E)
G has 24 voltsand R supplys all of these.
Now when it calls for defrost on a rheem does the board kill outdoor fan motor and break a contact in the (o/b terminal rv) and the aux heat is already going.
Is this right please advise.
NCSteve is offline   Reply With Quote
Old 02-03-2007, 01:13 AM   #2
Thoroughbred Mopar Man
Trade: Railroad Conductor/ Ex Hvac Service manager
Hi NCSteve
I think I follow the question you have. The reversing valve should be energised in the cooling mode. When it goes into defrost it shifts the reversing valve, stalls the outdoor fan, and energises the resistance heat. I hope this is what you were asking for, your post wasnt real clear.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 02-11-2007, 07:37 PM   #3
Trade: HVAC
RHEEM/Ruud Energizes in the heat mode. NOT COOLING. They are normally in the A/C mode un-energized. Carrier and most other brands work the other way. FYI
HVAC SERV OWNER is offline   Reply With Quote
trane thermostat question NCSteve HVAC 11 02-06-2007 11:33 PM
Feed back Please ,water heater Thermostat tzzzz216 Plumbing 4 11-11-2006 02:42 PM
Furnace Thermostat Setup Question skooter HVAC 4 02-22-2005 11:57 PM
