Is There A Way To Calculate Recovery From Setback Time?
Old 03-01-2018, 08:52 PM   #21
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,296
Re: Is There A Way To Calculate Recovery From Setback Time?
The floor really isn't responsible for that much loss. This is without slab insulation. Adding insulation halves the loss through the floor, so it would lower the overall heat load by about 1/8th.
The numbers are goofy for heat pumps since they are more than 100% efficient. That's why "heating system loss" is a negative number.
Golden view is offline
Old 03-01-2018, 09:08 PM   #22
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,174
What program is this? Did you do an actual blower door test or just assume your ACH50?
Philament is offline
Old 03-01-2018, 09:23 PM   #23
edward trowelhands
Trade: Diplomat
AKwarm. Designed for Alaska, but you can tweak it to work in other environments. I made a huge assumption for my ACH50. I can usually guess a house pretty well, but this is a pole barn. It'll be all foam though so should be pretty tight. Maybe the overhead doors will be really leaky though.
Old 03-01-2018, 09:48 PM   #24
Philament's Avatar
Interesting little program. I didn't see an area to change the weather file, seems fixed to alaska. how do you change it for your location?
Old 03-01-2018, 10:03 PM   #25
edward trowelhands
Trade: Diplomat
Alaska is a big state. I picked a close weather city and set the thermostat setpoint lower to compensate from there.
Old 03-02-2018, 06:39 AM   #26
hdavis's Avatar
Rewards Points: 8,831
Originally Posted by Fouthgeneration View Post
Used Carpet/wood flooring on the shop floor would insulate it lowering the BTU load per hour greatly....just throw it away every year and replace
"Horse barn mats"? much easier to sweep and Vacumn.
Great for standing on, but over $1.5 / sqft even for cheap ones. Plus, they can shift.
hdavis is offline
Time Stamp of posts Builders Inc. Contractor Talk Tutorials - How To Use This Site 3 11-15-2015 10:13 AM
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 06:43 PM
Need to hire full time repair man/woman in phoenix arizona, now!! Phoenix8 Help Wanted or Looking For Work 24 05-16-2012 04:39 PM
Recovery Time CPlumb Plumbing 9 02-23-2008 11:10 PM
