Temperature Difference ( Indoor Split)
Old 09-02-2014, 04:52 PM   #1
bhiggins's Avatar
Trade: Building maintenance
Rewards Points: 32
One of My ac systems is not cooling right now. The fan works, air is blowing, condenser and evap coils are clean, filters are clean, evap drainage is clear.
Air temp. at first register is 57.6 while Tstat is 76 ( set point 73),
bottom register( bottom of stairwell) 55.8*!
Also there is condensation moisture at the first register. The duct inside is dry.
This stairwell used to stay at 73* all the time.
The last few days have been hotter that's true
Clearly I have to call in the HVAC technician, because I don't mess with refrigerants, but what is going on here?
Are temp differentials normal, or should the air coming out of vent be colder?
Just trying to learn.
bhiggins is offline
Old 09-02-2014, 06:33 PM   #2
Thom
thom's Avatar
Rewards Points: 4,748
Re: Temperature Difference ( Indoor Split)
Should be approximately 20F difference between return and supply air. Ducts in attics may warm with the air warming as it goes through it. There will be temperature differentials in a house, those differentials will change with air leakage, sun angle, and open/closed doors.
condensation is about humidity, specifically the register is colder than the dew point. Dew point is a function of air temp and relative humidity.
You don't say which side of the blower the evaporator coil is on. If the coil is on the negative pressure side of the blower then you need water in the condensate trap to keep the system from sucking in outside (and probably humid) air through the condensate line.
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
Old 09-03-2014, 09:22 AM   #3
bhiggins's Avatar
Rewards Points: 32
This morning 9:00 am, the Tsat is back to 73*, same as set point.
I'll just keep an eye on it.
bhiggins is offline
Old 10-15-2014, 07:33 AM   #4
Peewee's Avatar
Trade: hvac
Rewards Points: 14
As an hvac tech of 15 years I don't still understand the concept of a delta average (split) as any form of conglomerate.
I keep my home at 70 set point. supply air temp on average (r22, yeah, I know) is 61. are you telling me that my 9 degree delta means my system is not working properly? Overcharged? isn't that what a low delta means? And in case you didn't catch that, my return temp is average 70.
Well since this delta has no substance than I guess my relative humidity has no poignance either,correct?
Delta, return and supply, is not a truth. It's an excuse, a weak and impermissible bypass, for those thinking hvac is not truly rocket science..
delta means nothing. not in these considerations, at least.
Peewee is offline
Old 11-01-2014, 08:11 AM   #5
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,078
Depends on where you are measuring the delta at.
beenthere is offline
The Following User Says Thank You to beenthere For This Useful Post:
flashheatingand (04-25-2017)
Old 04-24-2017, 06:53 PM   #6
Ron R's Avatar
Trade: HVAC
Rewards Points: 4
There is a company that makes a nice delta T AC Monitoring box (hardware and software). See http://www.mhvacmonitor.com
Ron R is offline
Old 04-24-2017, 07:10 PM   #7
Bull Trout's Avatar
Rewards Points: 182
Did you pay for this add Dr Ron?
Bull Trout is online now
The Following 2 Users Say Thank You to Bull Trout For This Useful Post:
beenthere (04-25-2017), dayexco (04-24-2017)
Old 04-25-2017, 04:38 AM   #8
beenthere's Avatar
Trade: HVAC
For a hundred bucks less, you can get a Honeywell Thermostat that will monitor the temp delta.
Old 04-25-2017, 10:05 AM   #9
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,416
I would want more than a 9 degree split. But, we deal with dry / sensible heat, more than latent heat.
If you are happy, great.
http://www.37flash.com/
flashheatingand is offline
Old 04-25-2017, 10:13 AM   #10
Trade: H.v.a.c.
Sometimes it takes a bit of time to figure out what is going on. We go to a house, and all is working fine. You can't just say "all is well, call us when the problem re-arises". Sometimes, one has to stay on site for an hour plus to catch the culprit.. Not there, but, as a betting man, I would go with either a blower motor, or condenser motor.
Old 04-26-2017, 05:16 AM   #11
beenthere's Avatar
Trade: HVAC
Flash. This a 2.5 year old thread. That Ron R revived to spam his product.
Bull Trout (04-26-2017)
Old 04-26-2017, 10:19 AM   #12
Trade: H.v.a.c.
DoAH. I am losing it, man, losing it.
The Following 2 Users Say Thank You to flashheatingand For This Useful Post:
beenthere (04-26-2017), Bull Trout (04-26-2017)
Old 06-13-2017, 06:29 PM   #13
www.acrepairslasvegas.com
Jrock's Avatar
Trade: HVAC
Rewards Points: 6
I highly recommend the Honeywell, we have been using these for years and our customers love them.
Jrock is offline
Old 11-29-2017, 11:38 AM   #14
PlumbersDenver's Avatar
Trade: Plumbing, Heating & Air Conditioning
Rewards Points: 12
Going to chime in here and say this is probably the most cost effective option!
PlumbersDenver is offline
The Difference Between Living and Existing Cricket Off Topic (Non Trade) 9 06-18-2014 06:08 PM
difference between self-leveler and rapid set concrete? MichaelEmerson Flooring 9 04-11-2011 08:09 PM
Difference in Code Between States michaelzenga999 General Discussion 9 04-03-2011 09:13 PM
Difference between Direct-Vent & Power-Vent HWTanks Crispy Plumbing 8 11-25-2009 07:11 PM
What is the difference? CaptainConcrete Business 9 11-06-2009 10:11 AM
