Tankless For Baseboard?
Old 02-17-2008, 08:50 PM   #1
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
Question
I have seen Tankless Water Heaters for Radiant Floor systems hydro Air systems and domestic hot water, but is it possible to use them for Baseboard Heat? I can't see why not, but when I checked with the Supply House they came up blank.
Has anyone done this?
Here is the background: Oil Burner will need to be replaced soon. I want to get off oil. I'm heating my house with wood and its working fine, even down to 7 degrees outside I am able to keep the house at 71 degrees inside. I only use the oil burner for the domestic hot water now and occasionally if we go away for a few days. So I know I can got to a tankless on demand for the DHW but I would still need something to supplement the Wood Stove when we are away.
LNG24 is offline
Old 03-01-2008, 10:50 PM   #2
HVAC Tech
cropper's Avatar
Trade: Currently a sevice supervisor with a chronic tool fetish
Re: Tankless For Baseboard?
The manufacturer usually frowns on rads due to the higher temps. 180 for copper finned or 140 for larger cast . They like the in floor and coils in airhandlers due to lower return water temps. But it does work in a pinch.
cropper is offline
Bosch Tankless sfoerst@excite. Introductions 2 01-24-2008 06:11 PM
Gas Tankless Water Heater - Good as their Hype? HepaCore General Discussion 11 01-17-2008 03:46 PM
Solar & tankless combined ExpressFive Plumbing 4 11-29-2007 10:16 PM
prefered tankless water heater rhinoguy Plumbing 9 03-14-2007 09:57 PM
Tankless water heaters? Tenspound Plumbing 20 06-21-2006 11:37 PM
