Trade: H.v.a.c.
Supply Vents In The Floor Or Ceiling?
Just a question about duct design, and what others think.
Personally, (in general) I think it's better to install the equipment in the attic. And run the supplies in the ceiling. My reasoning is:
#2 | |
Re: Supply Vents In The Floor Or Ceiling?Quote:
![]() From the long term outlook, the attic is the worst place. It's outside the envelope, access is problematic, ceiling joist aren't necessarily designed to be load bearing, noise transmission is at it's worst through the ceiling, service is more difficult, HO's are least likely to change filters in the attic, and condensate leaks go...where? High registers are good for cooling, but make for cold drafts at floor level in the northland winters. Other than all that locating the plant in the attic is a great idea. ![]()
depends what you are delivering through the duct work, reno or new construction, house design, climate etc.... in general our new construction which moves both heat and cooling through the ductwork, 2nd floor from attic in cielings, 1st floor from basement in floor.
#4 | |
Trade: H.v.a.c.
I don't intend to sound argumentive or defensive. I wanted to hear other opinions, and appreciate what you say. In order to limit potential problems, one needs to listen to what others have to say and address those issues. Once again, thanks for your reply |
#5 | |
![]() When we don't the second choice is usually in a utility room along with the W/H, washer/dryer. Last choice would be the attached garage (which then would be insulated and drywalled of course). Glad to meet someone else who doesn't require everyone to agree with every word they say. ![]() ![]() Where are you? Seems like attic furnaces were a southern invention. ![]() h
Trade: Plumbing & Gas Contractor
My ducts are in/under the slab and I don't like it.From what I understand ,if there is a break in the line at a joint from settling,there is no repair for it.And when it does go,it will start shooting dirt all over.Oklahoma is the only place I remember seeing this.A customer of mine had his system changed to a up-flow, after only 25 years his ducts failed somewhere,and that set him back 14,000.The home is only 3,500 sq or so.I dread the day,if and when.
Trade: hvac
preferrebly you should locate heat runs in the floor, attic systems can be very inefficent if not properly insulated as attick temperatures can be extreme(hot and cold depending on your climate). heat will penetrate the sheetrock and to prove this if you have a infrared thermometer take several readings off the floor walls and ceiling, on a hot summer day you can expect the ceiling to be quite higher if you only have conventional insulation. Locating your equipment in the center of the house is a great idea if it is feasable. my advice to you is get some duct design and load calculation manuals. these will awnser alot of your questions.
Trade: Retired
deleted
#9 | |
Trade: H.v.a.c.
| Noisy vents. | RoadMike | Introductions | 3 | 08-12-2008 03:09 PM |
| seal gable vents after ridge vent installed? | tacoma5050 | Roofing | 26 | 01-18-2008 10:50 PM |
| closing vents | ELM | HVAC | 10 | 11-10-2006 05:59 PM |
| Copper vents -vs- plastic/aluminum | shopman | Roofing | 2 | 03-01-2006 08:51 AM |
| Flushmount Light with MIN 90C Supply Conductors | kpikul | Electrical | 1 | 11-15-2005 06:41 PM |
