Strong Odor When Starting Air Conditioner
Old 08-11-2009, 11:11 PM   #1
Since 1977's Avatar
Trade: General Construction and Excavating
I have a client who was away for vacation. When she returned home and 'fired up the air cond. ' in about 7-10 minutes she noticed a strong smell. Originally it was feared to be natural gas.
I checked the lines inside and out with a detector....nothing.
This has possibly a smell like cat urine [ she just bought the house a year ago] but she has no pets. There are two 'black' spots/rings [urine spots?]on the hardwood floors which she has had professionally re-sanded and clear coated.
This has happened three times, she doesn't want to turn the system on for fear.....
has anyone run into this?
Also. I see plugs in the downstairs trunks that appear to be 1" dia. and I assume they are duct cleaning plugs...not sure.
Any input is appreciated, Thanks!
"I thought I'd been everywhere man.....then I ended up here"
Since 1977 is offline
Old 08-11-2009, 11:15 PM   #2
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Re: Strong Odor When Starting Air Conditioner
Could've had critters in the ductwork. Racoon scat smells a lot like that...
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 08-11-2009, 11:18 PM   #3
Since 1977's Avatar
Say it aint so.....thats what i told her we may have to take down some main trunks....
it only happens with the cold AIR conditioning... not the furnace/forced air
Old 08-11-2009, 11:27 PM   #4
Builder/Remodeler
ChrWright's Avatar
Chasing smells can be like chasing ghosts.
I had a client with a strange smell a few years ago that went on for months in only one room of the house. It smelled like an electrical fire with a little stinky sock thrown in.
We sniffed and poked and prodded around trying to figure it out--thinking it was a dusty furnace coil, or a shorted outlet, or something buried in a wall.
In the end it turned out to be an old area rug.
Old 08-11-2009, 11:43 PM   #5
flashheatingand's Avatar
Trade: H.v.a.c.
It wouldn't hurt to spray the evaporator coil with a bleach/h2o solution. Might as well give it a cleaning. Use a condensor coil brush and brush "with the grians" try not to bend the fins on the coil.
flashheatingand is offline
Old 08-11-2009, 11:44 PM   #6
Look at the tray at the bottom
of the A coil.
If it isn't draining well, some
nasty crap can start to grow there.
Sitting warm and stagnant while
she's away might be enough.
neolitic is offline
Old 08-12-2009, 12:44 PM   #7
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
its probably mold mildew or bacteria building up in the condensate drain. a good areosol coil cleaner or a bleach solution over the coil and through the drain should take cake of the odor. unless its more sinister than that!
NickTech is offline
Old 08-12-2009, 11:42 PM   #8
Since 1977's Avatar
Thanks to all of you for your responses,going there tomorrow to check the suggested areas.
Old 08-12-2009, 11:47 PM   #9
Builder/Remodeler
ChrWright's Avatar
Here's hoping it's just a little mold on the coil...
Old 08-14-2009, 08:45 AM   #10
DuMass's Avatar
Trade: EC/ACR
Wondering if it might be dirty sock syndrome. I agree that a good place to start would be to clean and disinfect the evaporator coil and condensate drip pan. You may also want to spray the plenum with some Hydro Balance duct and coil disinfectant/deodorizing spray as well.
DuMass is offline
Old 08-16-2009, 05:07 PM   #11
Since 1977's Avatar
Well I wanted to report that it was.. in fact... buildup from her having the HUMIDIFIER running full time since she got into the home about a year ago!
So we vac'd it out and cleaned/ disifected the coil and told her to keep the 'juice box' off until winter and the static builds up to where her hair is standing on end.
Thank you for all the responses........
Put a fork in this one... its DONE.
The Following User Says Thank You to Since 1977 For This Useful Post:
ChrWright (08-16-2009)
Old 08-16-2009, 05:46 PM   #12
"...and they lived happily ever after."
Thanks for coming back to
end the story.
neolitic is offline
Old 08-17-2009, 09:19 PM   #13
DuMass's Avatar
Trade: EC/ACR
Glad you got the odor under control. It sounds like maybe her humidifier isn't hooked up correctly though. In my area, they are normally connected to run only when the furnace is in heating mode and the blower is running, regardless of the humidistat setting. Also wondering why she would want to be able to add humidity to the air during the cooling season, with the AC running? This seems counter productive.
DuMass is offline
Old 08-17-2009, 09:49 PM   #14
Trade: H.v.a.c.
We also hook the humidifier to only operate in Heat Mode. There are exceptions, but, generally, you only want the humidifier to run while the furnace operates as it's the furnace that dries out the air.
The problem is done this year, but if there was a funk caused, I would suspect a problem with the condensate run. It's easy to "do it right" with a condensate pump and run the line to a utility sink, or washer drain.
Old 08-18-2009, 07:43 AM   #15
delta l's Avatar
Trade: Lighting automation
Isn't bleach corrosive to aluminum fins?
delta l is offline
Old 08-18-2009, 09:30 PM   #16
Trade: H.v.a.c.
I wouldn't spray straight bleach on the coil, nor would I advise someone to clean with bleach on a regular basis. But I don't forsee any major damage happening if done once in awhile.
You can pump the system down, and pull out the coil, give it a thorough washing, but in the interest of keeping expenses in check, a little bleach water should be alright.
starting Media Blasting business kell490 Sandblasting 185 08-17-2010 07:06 AM
Starting a new business - advice wanted Panzer5 Business 28 08-03-2009 07:01 PM
Min. post before starting thread? Deadhead Derek Site Help and Suggestions 21 02-16-2009 09:05 PM
Advice for starting Career as Operating Engineer TrendTherapy Excavation & Site Work 0 02-13-2009 11:07 AM
Info on starting business bryank1202 Business 8 09-19-2008 11:32 AM
