Trade: Industrial electronics
Sourcing An Older Gas Furnace Valve
Hey folks,
Any one know where I can find a gas valve for an older Tappan gas furnace, model GWF 80D48E3? My local supplier says "no gots," and I haven't found one on the net. Got some time to find one as I have the gas capped off for now, but the fall is coming, and i'd really like to replace the valve and not the whole unit, albeit it's old. Thanks for your thoughts |
Trade: H.v.a.c.
Re: Sourcing An Older Gas Furnace Valve
You should be able to install a universal gas valve. I don't know about the specifics of that furnace, but with a little "know-how", it can be done. If you aren't sure of "how to", you should be able to find somebody locally who could make it work. If this a standing pilot furnace, spark ignition, or hot surface ignition system? If it's an older model, it's likely to be a standing pilot.
Good luck |
yes, it a standing pilot. I've been looking into some of the white-rogers universal units. Probably get one on Ebay and give it a shot. thanks for your thoughts
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Shudder!
Trade: HVAC Service Technician --RSES CM-- NATE Certifie
Any streaking or staining coming out of the burner box cover? If so get a new furnace as you most likely have a crack, rust perforation or leaking heat exchanger seam. With natural gas prices going up another 20 - 30 percent why not get a new 90 - 95 percent efficiency furnace? Your present furnace when new had an efficiency of 60 - 75 percent.
MechAcc's Carbon Monoxide Site Links |
| Heil furnace static switch | ronnyd | HVAC | 0 | 04-13-2008 09:30 AM |
| Goodman 80% furnace brand new won't start | Hguy | HVAC | 21 | 03-29-2008 12:05 AM |
| Problem with Kohler k 304 valve....Help!!! | gitnerdun | Plumbing | 11 | 10-12-2007 10:57 AM |
| Furnace pilot shuts off while turning gas valve to on | Nocturnal2010 | HVAC | 1 | 03-04-2005 06:21 PM |
| need info on a goodman gus 075-3 older 90% furnace | haank | HVAC | 0 | 09-29-2003 11:02 PM |
