Small House / Small HVAC Budget
Old 09-20-2004, 09:00 AM   #1
Losinglouie's Avatar
For a small new construction project in the mountains, which will get both some snow and some heat but no humidity, what system might you recommend for HVAC? It is 1200 SF, two story, propane or electric operated, and energy effeciency not the main driver. I do not know my R values yet. Thanks. Budget $6,700 installed with all duct work. Thanks a lot! L.L.
Losinglouie is offline
Old 09-20-2004, 11:33 PM   #2
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
Re: Small House / Small HVAC Budget
Depending on your electric rates and any Power Co. rebates, go with a heat pump with electric back up for the "cheaper" of the equipment initial cost. Don't know what your gas rates are around that area but here, it isn't cost effective to do anything less than a 90%+ furnace (on Propane) unless you plan on being in the home less that 5 yrs. Get at least 3 bids from reputable contractors and make sure they do a load calculation to size the equipment and Manual D to size the duct system correctly.
HVAC Doc is offline
Old 09-21-2004, 09:05 AM   #3
Thanks for your reply. I will look into the heat pump further. Best wishes, L.L.
Did you see Flip this house - Cat House? SuperiorBuilt Off Topic (Non Trade) 18 01-24-2011 05:17 PM
`Flip This House' star accused of fraud AmeliaP General Discussion 28 06-03-2007 10:21 PM
Best way to ventilate a hot house? SuperiorBuilt General Discussion 12 06-03-2007 01:40 PM
Line of credit for spec house? ruskent Business 2 05-13-2007 07:56 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
