"Out of plane" F/D Installation:
First off: there are integral Out of Plane F/D sleeves out there, I know.
Do any of the sheet metal guys out there know where to locate the
SMACNA variation showing acceptable installation of out of plane F/D? We've encountered a minor snag with such a F/D (Funny thing is there wasn't one there before, but all things come to an end eventually).
The floor it passes through is pre-cast hollow core. The way we've installed it was:
- F/D in Standard sleeve. Riveted in place to allow secondary sleeve later. (Horizontal Install)
- Unit Placed above "Fire separation" and angled off, riveted again. (Sleeve continues through)
- Secondary 12 ga Sleeve of welded construction over top of initial Fire Damper sleeve.
- Fire caulk around seams where space exists between primary and secondary sleeve & at floor penetration.
Note:
- NO caulk came into contact with the F/D to ensure it wouldn't distort.
- "Concrete" Floor is pre-cast & had no F/D in place initially. We placed the F/D out of plane as it was not possible to cut the concrete without risking even greater damage to the floor. Thus we didn't cut the hole larger to accomodate the Integral F/D
Suggestions, need a laugh?
Thanks for any
USEFUL suggestions!
