Trade: underground
Should I Call For Service?
I have a Whirlpool (Heil / Quaker) "high efficiency" gas furnace rated at 100K BTU/HR. The model is NUGK100AH01. It's the kind that exhausts out the side of the house through a 1-1/2" or 2" PVC-40 pipe. It keeps the house warm just fine, even on very cold days. This time of year I always see steam coming out of the exhaust. It also constantly discharges water into a floor drain. Lately I've noticed that the thing inside the front of the furnace that looks like a turbo-charger is cycling on and off - even when the blower runs continually. Does this neccesarily indicate a need for service? Burners are good and blue and there's never any ignition problem.
The Doctor is In!
Trade: HVAC owner
Re: Should I Call For Service?
Check out side and make sure you do not have a build of ice that might be causing it to trip the pressure switch off then back on again. Has it been extremely windy where you might also be getting a good gust of wind down the pipe tripping the switch as well?
#3 | |
Trade: underground
Re: Should I Call For Service?Quote:
Don't think wind has been too much an issue though I may have noticed it more the other day when it was gusty. I'll be more conscious of the outside conditions when I hear it cycling. Thanks again. If it keeps it up I'll be sure to CALL A PRO. |
Trade: underground
Hey, I just thought of something else. There's some kind of funky looking PVC-40 type of canister assembly down on the floor alongside the furnace. It has various small pipes and tubing running in and out of it and ultimately goes to the floor drain. Does that thing require servicing? I've never touched it.
#5 | |
The Doctor is In!
Trade: HVAC owner
That is your condensate pump. You might pop the top off and make sure no mold or goop is growing in it. Normally, those do not hamper a furnace from operating unless the dump straight outside and the outlet is frozen |
| Pay Per Call Ads | dougchips | Marketing & Sales | 6 | 10-15-2006 07:48 PM |
| One call close | jensenconstruction | Marketing & Sales | 2 | 05-31-2006 10:52 AM |
| one call method | dayexco | Excavation & Site Work | 18 | 05-05-2006 09:33 PM |
| Call alert | reveivl | Technology | 4 | 11-12-2005 12:36 PM |
