Trade: HVAC
Service Valves
Lost freon charge on unit. Removed service valve cap covers and closed service valves to do a vaccum test on lines and evaporator. vaccum slowly leak down. put pressure on lines and soap test connections. Valves were leaking alot at valve stems.Have read that caps are the primary seals.Is this true or do I need to replace the service valves or can they be rebuild . Should I look for leaks else where in unit.
Trade: hvac
Re: Service Valves
if the leak is coming from the schrader just change it...buy the tool and a new schrader valve and replace it
Trade: hvac tech
Re: Service Valves
hi the seal inside usually gets burnt due to excessive heat from brazing.u could try some oil on them ,then spin them in and out a few times and loctite the caps as well as changing schraders.kind of a mickey mouse fix.just finished a call,what i did was eliminate valves altogether and install service ports.little more time consuming but after 200 psi of nitro and 1/2 hr later i know it'll be a long time b4 i'm back ther ,,, good luck
HVAC Tech, NATE certified
Trade: Hvac technician. Boehmer Heating
Re: Service Valves
they sell a piece, i believe its called an L bend?? but you screw it over the existing service valve, and it has its own schrader port on it to use. just leave it on and use it as your new service port.
| Google search for a contractor, bathroom | Mark Daniels | Online Leads Services | 7 | 12-25-2009 12:35 PM |
| Service Magic's new service | Grumpy | Marketing & Sales | 12 | 08-02-2008 04:31 PM |
| Difference between new work and service | mdshunk | Business | 2 | 09-09-2007 01:19 PM |
| Can anyone make any sense out of this? | Teetorbilt | Technology | 24 | 04-16-2007 12:21 PM |
| May offer a New Service ?? | tzzzz216 | General Discussion | 15 | 07-16-2006 12:00 PM |
