Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 05-01-2009, 09:04 AM   #1
AFCC Inc.
erikkl2000's Avatar
Trade: Home Builder / IT for Building Industry
SEER Raiting
Can someone give me a dummy version of what SEER ratings really mean?
Every success begins with a plan
erikkl2000 is offline   Reply With Quote
Old 05-01-2009, 01:56 PM   #2
Trade: HVAC
Basically, the lower the S.E.E.R. rating, the more energy (electricity) is required to produce the desired effect.
EXAMPLE:
S.E.E.R. OF "6"
(6 is a very common rating for older units produced prior to the 1990's, when energy was relatively inexpensive)
Produces about 6 BTU/hr of cooling, per watt of electricity
S.E.E.R. OF "12" (12 is very common for newer high-efficiency units)
Produces about 12 BTU/hr of cooling per watt of electricity
This would be about double the cooling effect of a 6 S.E.E.R. unit
I have a good link to a paper that explains it but I have not made 15 posts so I cannot post it here.
TK03 is offline   Reply With Quote
Old 05-01-2009, 06:49 PM   #3
Trade: HVACR
SEER = [Total Cooling Output Over the Cooling Season] / [Total Electrical Energy Input Over the Cooling Season],the higher the seer rating typically means the more efficient the system will operate, or in other words a much lower energy cost to cool the space. Older air conditioning systems are likely to have a lower SEER (perhaps 5 or 6) than a newer more efficient system (perhaps SEER=12). The higher the seer rating the more likely a system will lower a customers electrical bill considering all else is good, ex. building insulation, location, duct system,etc.
Remco Air is offline   Reply With Quote
13 to 16 seer heatpump? offpiste HVAC 10 07-17-2009 08:42 PM
Miss matched equipment. wrobert4 HVAC 18 12-27-2008 12:19 AM
Residential HVAC pricing aseid HVAC 20 07-09-2008 10:50 PM
Heil 10 Seer VS Trane XR13 Chris.Peer HVAC 6 07-11-2006 07:55 PM
Opinions on unit and advice on SEER rating daveincincy HVAC 2 04-18-2006 12:20 AM
