tile mason
Screws In Flue Pipe
I had a new furnace installed in attic and condensor outside.
I went upstairs after they left and had to silver tape and duct seal the bottom myself. Then I noticed there are 1/4" screws in the flue pipe system. I thought it was against code to put screws in flue. Am I wrong?
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
Trade: Squirrel Handler
Re: Screws In Flue Pipe
I'd wait for the HVAC guys, but I think you're wrong, it's no screws in dryer vents, because of the lint, I'm not sure if that's a code or just common knowledge.
What else could you use that would stand up to the heat. .
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
#3 | |
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Re: Screws In Flue PipeQuote:
Is this B vent or just single wall pipe? OR PVC or CPVC? |
Plumber / Carpenter
I always thought you had to install at least 1 so as to keep the pipe from coming apart
#5 | |
Trade: General contractor
Our hvac guys use 3 screws per connection in single wall. |
Trade: HVAC/R
3 evenly spaced screws for b-vent. Obviously can't be done with dryer vent/
Trade: Heating, Ventilation, Cooling & Sheet Metal
B-Vent requires screws as well. They are a special screw though, shorter, so as not to pierce the inner liner. Try to always place AT LEAST two screws opposite each other. One is really insuffiecient to prevent a pipe from coming apart. Best practice is minimum of 3 up to about six inch.
"They must find it difficult...Those who have taken authority as the truth, rather than truth as the authority." - Gerald Massey |
The 1/4" hole could have been from combustion analysis. Not sure of the code in your state, but it may be required when commissioning new equipment. They may have forgotten to place the Foil/aluminum tape over the holes once completed.
Last I knew screws were NOT allowed for B vent in any shape or form. Can anyone cite the code where they are required?
Professional Instigator
Screws are not required in DC.
In fact there are brands that tell you not to insert screws in them. I think the biggest mfg fear is you will probably puncture the liner. There are atleast two companies that sell a snap together system. If a screw has to be inserted I use a 3/8 screw and tape it. |
#11 | |
I still haven't reached the "Critical 15 post minimum" so I'll be unable to paste links. It's out there if you look. Even in the states it appears as though manufacturers tested item(s) IS the code above authority having jurisdiction.,
HVAC Tech, NATE certified
Trade: Hvac technician. Boehmer Heating
we aways use screws in single wall paipe, just to keep it from slipping apart. Even the best tape loosens after awhile (UL 181 tape). If anything puts pressure on it tape alone isnt enough.
| Drain Pipe | denick | Excavation & Site Work | 18 | 07-12-2009 04:41 PM |
| Gas Pipe Question.... | drbigfresh | Plumbing | 9 | 02-28-2007 03:51 PM |
| Using Flex Pipe | dirt diggler | Pool Construction & Enclosures | 8 | 02-25-2007 04:30 PM |
| flue pipe soot problem | magnum | General Discussion | 4 | 12-15-2005 10:17 PM |
| How to trace gas pipe? | karma_carpentry | Carpentry | 15 | 11-30-2005 11:47 AM |
