Rheem T-stat
Old 12-17-2006, 09:46 AM   #1
MSSI's Avatar
Trade: Electrician
Rheem T-stat
Has anyone delt with these new Rheem"stamped" touch screen tsats? "fully modulating" The thing seems to only take a temp reading every 10mins or so. If I jack up the set point more than 3 degrees the system cranks out max heat and it will get up to like 80-85 degrees(set point 72) because the temp reading on the tstat only goes up 1 degree at a time. Its seems like it takes at least 30 mins to catch up,, by this time the temp in the house has dropped back down as well.
Also it keeps heating(at lowest output) when it hits the setpoint which by the way is about 3 degrees off(low of actual)
MSSI is offline
Old 12-18-2006, 11:01 PM   #2
sloooo's Avatar
Trade: HVACR
Re: Rheem T-stat
I haven't dealt with them, but how programmable are they? Are they PI (D) controlled? If they are, you need to turn down your ramp rate so it ramps slower to get to the current set-point.
sloooo is offline
Old 12-19-2006, 06:34 PM   #3
MSSI's Avatar
Trade: Electrician
Re: Rheem T-stat
I can program about 40 different parameters.. I will look for something of the sort you mentioned.. This thing just doest read actual temp. in real time........Thank you
MSSI is offline
Old 01-05-2007, 08:16 PM   #4
trollmaster's Avatar
Trade: hvacr & building contractor
Re: Rheem T-stat
Rheem doesnt make there own thermostats. ( lets face it rheem cant even make a good furnace opps ,sorry ,did I say that ?) Try to see under the cover if you see another name like white rodgers ,honeywell ,or something else.
trollmaster is offline
Old 01-06-2007, 07:01 PM   #5
Thoroughbred Mopar Man
#CARRIERMAN's Avatar
Trade: Railroad Conductor/ Ex Hvac Service manager
Re: Rheem T-stat
Hi MSSI
I have never got the chance to mess with the one Rheem/Ruud uses. I believe it is built by Robertshaw, have to say good luck there lol. I believe the solution to your problem could either be one of the dip switches in the stat not set right, or the software is not set up or could be corrupt. I would go back into the stat and check the configuration, I bet you will find it there.
Rusty
Good luck
Rusty
#CARRIERMAN is offline
Rheem Heating/AC tate16t HVAC 1 11-26-2006 11:50 PM
Water heater Help tzzzz216 Plumbing 10 11-22-2006 03:30 PM
rheem ? MSSI HVAC 2 07-11-2006 10:58 PM
rheem rudd heatpumps wiring diag help airtech HVAC 1 11-25-2005 09:14 PM
Payne and Rheem Unregistered HVAC 8 11-09-2004 12:27 AM
