Retrofiting A Fireplace
Old 10-27-2006, 04:03 PM   #1
willl's Avatar
Trade: flooring
I got a room with a fireplace in it that is heated primarily by electrical heaters that are installed in the walls. I was wondering if it be possible to change the wood burning fireplace into a natrual gas burning fireplace. It is your common wood buring fireplace though with a damper etc. on it. Natural gas will be cheaper and will also look better since it is in a fireplace. I don't know whether or not this is a good idea or not. Thanks
willl is offline
Old 10-27-2006, 09:23 PM   #2
troubleseeker's Avatar
Re: Retrofiting A Fireplace
A wood burning fireplace can be converted to gas logs, but it may not be cheap to do.You may have to open a piece of wall along side the fireplace so the plumber can get the gas line and control valve in a convenient place, usually within an arms reach of the logs, so you can reach to light them. Also. is there a gas supply close for him to tap into, or will you need a long pipe run? And a realistic burning set of gas logs is not cheap. Do not buy logs until you have gone to a supplier where you can see them burn. The more expensive sets are very convincing, but the cheap sets have all the charm of watching a gas cooktop flame.
Since you will be going to dedicated gas, I would also consider paying to have the chimney cleaned professionally. Built up creosote from years of wood can result in a very nasty chimney fire.
troubleseeker is offline
Old 10-30-2006, 08:14 PM   #3
hf05's Avatar
Trade: hvac tech
u need a gas insert that vents up your existing chimney with a 4" liner.Can get with blower ,remotes,thermostats,etc.etc.Initial expense,but in the long run probaly cheaper than hydro depending where u live...
hf05 is offline
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Gas Fireplace - To Vent or Not Hardibuilt General Discussion 8 05-08-2007 10:58 AM
Fireplace Insert Raised off the Slab Hambone Masonry 14 04-22-2007 09:54 PM
Fireplace Insert Raised off the Slab Hambone Construction 7 04-20-2007 11:57 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
