Removing A Radiator Temporarily
Old 02-20-2008, 07:44 PM   #1
fast pasquale's Avatar
Trade: Hardwood flooring contractor
So I have a boiler. It's a two pipe system. There are no vents on the radiators. So Im guessing this is a hot water gravity system?.. Anyways... I have the 2nd fl bathroom gutted and need to remove the radiator for a few weeks. I believe the supply pipe is 3/4 inch and the return is 1/2. What does this entail?? Can I just shut the system off.. wait for the radiator to cool off and back off each union and then cap it??...or is there more involved than this.. Thanks so much!!
Chris Frate
Pasquale Floors
fast pasquale is offline
Old 02-21-2008, 10:43 PM   #2
Re: Removing A Radiator Temporarily
Here's the answer.. btw.. It's a steam system. Chris.. All you have to do is turn the boiler off.. Make sure the rad. is cool and no hot water in it.. Back off the unions then the valves on both pipes. Cap them off well... Turn sytem back on. It's important to not just remove the union's off the rad. b/c you won't be able to find a cap for that thread...It's a hair bigger than 3/4.
Chris Frate
Pasquale Floors
Removing Tar from slab Brickie Concrete & Paving 2 12-29-2007 09:59 PM
Removing Tile On Concrete dougchips Ceramic & Stone Tile 20 12-01-2007 08:02 PM
Removing Old T-111 route514 Construction 20 04-24-2007 02:00 AM
removing old wallpaper daworz Drywall 5 01-26-2006 01:59 PM
Removing stain from a french door or replace? Mike F Painting & Finish Work 6 03-22-2004 10:46 PM
