Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 01-02-2008, 07:40 AM   #1
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
remote thermostat
I am a painter,wallpaper hanger by trade but also a homeowner in search of an answer. I have an old house with 1 pipe steam heat. We have lived here for 25 years listening to the sound of the radiators all hissing madly on the second floor and never thought much of it. Well I then learned that this was not right ,( as you guys know). I have replaced all the vents,adjustable ones to the 3 closest to the thermostat(adjusted as low as it will go,#1)and the system is working very well,that is, no more hissing. The problem is now the upstairs,and all other radiators farther away from the boiler barely get warm,even if the thermostat is set at 75. This means that the wife gets up to a COLD bathroom and this is not a good thing. I was thinking of a remote thermostat to put on the second floor. I know this is going to make the 1st floor very warm but the bathroom just needs to not be cold. Any other ideas? I am lost here.
Thanks
Chris
chris n is offline   Reply With Quote
Old 01-02-2008, 09:27 AM   #2
HVAC Old Timer
HeatPro's Avatar
Trade: HVAC
Adjust the steam air vents in the rooms
When the rooms upstairs and distant become cold, it is from the vents in those rooms having holes too small and the ones in the warm rooms, especially the room with the thermostat too large. Change/swap/adjust the vents until the heat is even.
http://www.heatpro.us/steamtree/docu...0D68C04F9.html
Moving thermostats to other rooms just makes the ones that are comfortable too hot otherwise.
http://www.heatpro.us/service/xtstat.htm
Many think it is the thermostat that does the house heating, really they just start and stop the burner in a steam system. Thermostats just sense the temperature in the room they are in. Remote thermostats sense the temperature of the room the remote sensor is in, they don't change the whole house. Residential steam systems don't favor zoning at reasonable expense; they are single-zone inefficient antiques left over in uninsulated houses that use three times the heat of a new house.
HeatPro is offline   Reply With Quote
Heil #10 heat pump thermostat craigww HVAC 3 08-28-2007 05:19 PM
Wireless thermostat Speedy Petey Electrical 5 02-22-2007 04:30 PM
Feed back Please ,water heater Thermostat tzzzz216 Plumbing 4 11-11-2006 02:42 PM
remote data backup PipeGuy Technology 3 06-09-2006 07:41 AM
New Thermostat for American Standard Supmac HVAC 2 12-05-2005 07:16 PM
