LS-4 Reference Leak
Hello all,
I represent the manufacturer of the LS-4 reference leak, HT Products based in Sussex, UK. You are correct that we don't have a distribution network in the US but this is something we are investigating, it's helpful to hear people making reference to our products.
The introduction of our reference leaks come in response to EU regulations on HFC leakage which specifiy a minimum acceptable leak of 5g/Yr from a charged system. Engineers can check their detectors against the reference leak which has a known + calibrated value and compare the readout to the value registered on a real leak in a system, even on a cheaper leak detector with no numerical display the engineer can get an idea of how a leak under investigation compares to the minimum acceptable leak under current regulations.
As to the questions over the sensitivity of different leak detectors to different gases then the use of reference leaks can provide information on this relationship e.g. sniff one reference leak for 5g/Yr R134a and one for 5g/Yr R404a and see how the display on the leak detector compares.
some more information on our other products is available from our website, type htproducts into a search engine.
many thanks for reading
Dave Percival
HT Products
