#21 |
Trade: HVAC, 22 year Journeyman- TinnerTech
Re: Refridgerant/evap Core Guru
"y valve/bypass loop at the pump to regulate flow, and fans on a rheostat, mabey putting a thermometer on the in and out at the coil will help fine tune it "
What you're talking about is called a "differential thermostat" (sp. sux, that's why I'm a mechanic, not a science teacher...) If you have a Johnstone Supply near you, they have diff.stats in stock, they also have TXVs which will help you on the flow regulation- they basicly work like a gate valve with a feedback circuit to keep a constant pressure supply at the outlet. (WAY more complex than that, but this gives you the idea...) TXV is a Thermal Expansion Valve- try Googling it, see if that helps you at all... C.Ray |
| The Following User Says Thank You to C. Ray Gill For This Useful Post: | Bone Saw (08-29-2009) |
