Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 03-04-2007, 07:40 PM   #1
Trade:
radiant heat system
I am researching a boiler/water heater combo that heats water for shower sink etc and also heats and pumps water through a radiant floor heating system. I would like to avoid baseboard units in the basement (exisiting slab-unfinished basement by the way). So here's the question: has anyone heard on laying down treated sleepers on the slab, running the pex tubing in the bays and installing plywood over that? Is there a way to heat the basement with this radiant system of tubing and fins without the exposed fixtures?
maderuyck is offline   Reply With Quote
Old 03-04-2007, 10:19 PM   #2
Thom
thom's Avatar
There are systems for installing radiant below a plywood deck. In this case, the slab will be an issue. Unless you properly insulate the system from the slab, you will spend a lot heating the earth.
thom is offline   Reply With Quote
Old 03-05-2007, 11:35 PM   #3
Astar Heating & A/C CEO
Trade: HVAC Contractor
Send a message via Yahoo to FemaleAstarCO
I am not sure how efficient it is but I have seen a flashing installed in this circumstance it reflects the heat. Good luck
FemaleAstarCO is offline   Reply With Quote
Old 05-07-2007, 09:13 PM   #4
Trade: plumbing heating &ac
radiant
You should insulate the slab with either foil bubble wrap or high r foam stadler makes a plastic mat you snap the tubing in and then you can pour another thin slab 1/12 inch and intall tile or lineolum you can use sleepers with heat transfer plates but will have to run water temp hotter and system wont heat up as fast make sure you do a heat load if you have alot of glass or real poor insulation you might not get enough heat from the floor
able14 is offline   Reply With Quote
Old 08-17-2008, 07:14 PM   #5
Trade: lumber production and sales
Wink Slab heat
Be very carefull about trying to retrofit in/on slab heating unless it has been designed and insulated to prevent the heat from escaping out from beneath the building. Usually floor convective systems have to be built in before the slab is poured. Loop length and piping distribution is important as well as manifold design. Infloor water pipes, 85 - 95 degrees, are not warm enough for DHW, 125 - 140, so this has to be a separate system. Also heat transfer, conduction, out of the pipes to air is substantially slower than into concrete slab and there is no heat storage by the mass of the slab so will have hot spots and fluctuating temperatures. get some engineering advice before proceeding.
sawyerEd is offline   Reply With Quote
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-01-2007 11:38 PM
radiant system help jacsul Plumbing 0 01-27-2007 10:46 AM
cherry mercier over quick track radiant heat ApgarNJ Flooring 8 05-22-2006 03:36 PM
Hardwood Floors over Radiant Heat bigtick Flooring 10 12-08-2005 03:43 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 03:38 PM
