Trade: Homebuilding
Radiant Heat Pipe Install Question
I've seen some radiant heat installs under a tile floor, for example, where pex was used as the medium to carry the hot water.
The pex is run through some type of aluminum "device" that's intended to help heat transfer (I'm assuming). This is fastened to the underside of the subfloor where the tile will be installed. My question is this, since the radiant heat has to "work through" the 3/4" subfloor that is wood (an insulator), I'm curious what the operating loss is vs. running the piping directly under the tile (ie, eliminate the need to heat the subfloor first). Are there any good websites etc that discuss this issue? |
Trade: commercial hvac repair and installations
Re: Radiant Heat Pipe Install Question
check out www.wattsradiant.com for some info
Trade: General
Unfortunately pex has a pretty good expansion coefficient so I don't think trying to bed it in the thinset would work,I use the electric matting for this reason.I do hot water radiant systems also and when the tubing is against the floor with the reflector plates,the water runs at a lower temp the thickness of the subfloor is taken into design consideration.The subfloor becomes a part of the thermal mass storing the energy brought up from the hot water, instead of insulating against heat flow up into the tile floor.
Plumbing is a Profession
Trade: Plumbing & HVAC
Wood floors do indeed effect the thermal efficiency of the loop. Thick floors and those with carpet pad and carpet perform even worse and require much higher water temperatures than in floor (thin-set) radiant piping. Typical temps for in floor run 85 -95 % and staple up systems can run as high as 180% Naturally, running higher water temperatures has a negative effect on the overall system efficiency, but people like the comfort aspect and are willing to make the ectra expense for the system.
Dr Heat
Trade: hvac
I agree that carpet and pad has an effect but a 3/4 inch subfloor is like R .75 rather insignificant and as stated earlier it accounts for mass. Even thin set will hold heat. you just need to figure it into your calcs.
Trade: Radiant Heat System
agree with nhmaster3015
Trade: hydronic design, installation and consultation
Radiant panel design depends first on the heat load for the room in question. When specifying the type of emitter, the load may exceed the potential output of the system.
PEX installed in the mud-set of a tile system, meets virtually no resistance to heat transfer and therefore can achieve high output without high water and surface temperature. Whether the output is adequate to the load has to do with insulation and glass. The expansion coefficient is of no consequence on thin-set, but profile could be a concern, so 3/8 and 5/16 PEX is available. For sub-floor systems an aluminum emission plate is often and properly employed, enhancing output by as much as 175% over a bare tube. As suggested, this system, though common and accepted, will require higher operating temperatures, which always cost more to operate. This is especially true of systems driven by condensing boilers or heat pumps. http://www.radiantpanelassociation.o...id=5#Product49 |
| Basement Slab with Radiant Heat | plazaman | Framing | 6 | 10-13-2008 05:35 PM |
| Any tips for electric radiant floor heat? | sage | Flooring | 12 | 09-05-2007 03:34 PM |
| Radiant Heat in Ceiling wiring | mtplus | Electrical | 14 | 07-16-2006 12:51 PM |
| cherry mercier over quick track radiant heat | ApgarNJ | Flooring | 8 | 05-22-2006 04:36 PM |
| Heat Exchanger Inspection Methods | MechAcc | HVAC | 3 | 04-14-2005 04:38 PM |
