Radiant Heat
Old 12-07-2007, 11:21 PM   #1
plgrm's Avatar
Trade: I am a self employed contractor
Radiant Heat
I am installing a radiant heat system in my home. I will be installing a zone in the basement cement pad. Do I have to put down 1 inch foam insulation under the tubing? I had not put that in my budget, the foam will cost me an extra $800.00!! It is a ranch and it will also have tubing between the floor joists.
plgrm is offline
Old 12-08-2007, 04:33 PM   #2
Future Mod...
rex's Avatar
Trade: Master Plumber
Re: Radiant Heat
foil backed double bubble wrap is sufficent also.....
rex is offline
Old 12-11-2007, 10:58 AM   #3
HVAC Old Timer
HeatPro's Avatar
Trade: HVAC
Re: Radiant Heat
The choice of putting insulation under the tubing is about just heating the heavy mass above it or the entire ground mass below as well. That is a time and cost choice. The better the thermal break between the ground and above, the quicker reaction and less costly the result.
HeatPro is offline
Old 12-11-2007, 04:32 PM   #4
SelfContract's Avatar
Trade: Home Remodeling
Re: Radiant Heat
More electrical energy use contributes to more global warming issues in future.
SelfContract is offline
Electric Radiant Floor Heat kpikul Flooring 15 01-27-2012 04:03 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
cherry mercier over quick track radiant heat ApgarNJ Flooring 8 05-22-2006 04:36 PM
Hardwood Floors over Radiant Heat bigtick Flooring 10 12-08-2005 03:43 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 04:38 PM
