Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 02-07-2008, 09:32 PM   #1
Trade: General Contractor/ builder/carpenter
Question
I heard of a person in our area that is burning diesel fuel in there home fuel oil furnace. I tried to google about any problems this would cause, didn't really come up with anything, then it came to me to ask the pros. I've never heard of it before, I was just wondering.
Thanks alot
justagrunt is offline   Reply With Quote
Old 02-07-2008, 10:29 PM   #2
cleveman's Avatar
Trade: custom home building
what is your location?
cleveman is offline   Reply With Quote
Old 02-07-2008, 10:45 PM   #3
#2 home heating oil and #2 diesel are basically the same. But home heating oil does not have to meet the low sulfur requirements that on-road diesel does.
Also they are usually dyed different so they can see if it is road tax paid fuel, red for home oil and blue or no dye for diesel.
And of course diesel is more expensive because of the road taxes added.
Many years ago I remodeled a old 1920's house that had a oil furnace. I was planning on replacing it but used it for awhile since I lived in it while remodeling. One cold winter day I ran out of oil, so ran down the road and bought some diesel to get by for a few days. and a few days later I replaced the oil furnace with a heat pump.
Kgmz is offline   Reply With Quote
Old 02-07-2008, 10:45 PM   #4
HVAC Old Timer
HeatPro's Avatar
Trade: HVAC
You will want to know which diesel fuel it is that is being burned, as that gives an idea to a fuel oil burner tech as to how to set the burner. In many areas, diesel fuel is the same as #2 fuel oil, some diesel fuel is #2 fuel oil with coloration, other grades of diesel will be a different 'weight' with or without winterization additives. Changing or mixing without caring about the viscosity can increase the possibility of a dangerous 'bad burn.'
HeatPro is offline   Reply With Quote
Old 02-08-2008, 09:19 PM   #5
Thanks alot----makes me wonder now if I can run fuel oil in my powerstroke.
Northwest Ohio
Firewall question Derek13 Commercial Construction 3 12-11-2007 04:52 PM
Can anybody answer this question? Chance Drywall 25 10-13-2007 08:22 AM
Basement Window Question gregt848 Windows, Siding and Doors 9 07-26-2006 05:29 PM
