Quad Goodman Furnaces
Old 01-19-2006, 10:09 PM   #1
broncofan69025's Avatar
Trade: plumbing,electrician, HVAC
Lightbulb
Has anyone ever put 4 furnaces together for a large heat project? My first inclination is to use isolation relays and twinning two at a time but was just wondering before I call the factory, if anyone else has tried this?
broncofan69025 is offline
Old 01-19-2006, 10:38 PM   #2
mdshunk's Avatar
Re: Quad Goodman Furnaces
Yep, I've seen 4 arranged just as you suggest in a restaraunt/catering hall, but with a little twist. There were two groups of twinned units. Each pair did not have an isolation relay (they had all four transformers ripped out, and one large 1000va one installed remotely), but they went through an alternator relay. The relay used was a pump alternator type relay, so that a different pair came on first each call for heat, equalizing the wear and tear. There was a two stage heat stat used to bring in the second pair.
mdshunk is offline
Old 01-20-2006, 12:12 AM   #3
sounds like that would work also, What I am trying to do is bring all four of them on at the same time. and was wondering if the twinning wire would work for more than one furnace in parallel so they all receive the same signal?? any thoughts?
Another Goodman GMP-075-3 problem rhinoguy HVAC 12 12-05-2010 06:52 AM
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-29-2008 12:05 AM
Goodman not cooling MikeT HVAC 6 07-05-2006 03:25 AM
2 blinks on goodman furnance? Herman HVAC 2 04-09-2006 11:16 PM
Goodman furnaces? oldgoat HVAC 3 02-22-2006 10:07 PM
