Newbie
Trade: Home Renovations
PTAC For Sunroom?
I have a client who wants a deck turned into a small sunroom/addition. After doing some research on my heating/cooling options, I have concluded that maybe a PTAC unit (or PTHP) might be the best bet for heating/cooling. I've usually seen these in hotels, apartments, etc.
Here are my questions: 1) Does this seem like a appropriate idea for heating/cooling or is there something else that would be better? 2) Is there a particular brand that anyone would recommend? 3) Which one is preferable? PTAC or PTHP? Other times I've run ductwork from existing units to heat/cool additions. In this case that's kind of impractical. Thanks y'all. Kevin |
HVAC Old Timer
Trade: HVAC
Re: PTAC For Sunroom?
The questions are a request for another 'popularity contest winner,' as a full answer requires 'laying out' the differences of why each kind or heating and air conditioning method is used and which brands people like for any reason. The answers also depend on the amount of glass, the shape, the use of the room, and the location.
For many people, the answer can be found in which kind of heating and cooling system they settled on after living in their own homes for 30 years vs their experiences in hotels and why they wouldn't like hotel heat and cooling. |
Trade: HVAC
I think it's a great idea for that type of room. Fedders Island Air makes a great unit that has gas heating/ electric cooling. I have an account with three hundred of them in an assisted living facility that are going on four years old with very few problems.
Trade: Facility Maintenance
Thanks for a civil answer
![]() ![]() ![]() : eek: |
Newbie
Re: PTAC For Sunroom? |
HVAC Old Timer
Trade: HVAC
The voting booth is still open:
I prefer: PTAC _resistance electric _heat pump radiant _floor __electric __hot water _ceiling _wall baseboard _electric _hotwater warm air _direct vent wall heater _central Because: I once had one. I sell them. I have small windows and good insulation. |
#7 | |
Trade: HVAC
Re: PTAC For Sunroom?Quote:
In plain unadulterated english, what the hell are you trying to say? |
HVAC Old Timer
Trade: HVAC
Pick one. Each person, depending upon circumstances, will tell their preference. There is no single perfect answer that fits all situations.
If this was a closed session to sell PTACs then I apologize, as I wasn't informed. Last edited by HeatPro; 12-19-2007 at 08:18 PM. |
#9 | |
Newbie
I believe that narrows your list down to: PTAC Central Heat pump Also as I said previously...other times I've run ductwork from existing units to heat/cool additions. In this case that's kind of impractical. So through a process of elimination I'd come to the conclusion that a PTAC might be my best bet for a scenario where I'm turning a deck into a small addition. So to reiterate...here are my questions: 1) Does this seem like a appropriate idea for heating/cooling or is there something else that would be better? 2) Is there a particular brand that anyone would recommend? 3) Which one is preferable? PTAC or PTHP? I recognize that some of this will vary based on the application, and the preference of the individuals, but I think I gave enough information to make the questions reasonable. Furthermore, part of the purpose of a site like this is to get the opinions of other pros. I am not an HVAC pro....so I thought I'd try to learn from your expertise. Thanks for any help you give. Kevin
Proverbs 18:9 "One who is slack in his work is brother to one who destroys." |
Trade: HVAC
[quote=HeatPro;339848]The voting booth is still open:
I prefer: PTAC _resistance electric too expensive to run _heat pump depends on the area and fuel available _radiant floor installation expense too high __electric unless your in the TVA that's out __hot water best heat in my opinion but depends on existing system _ceiling it's above the floor _wall adjacent to floor and ceiling baseboard _electric operating cost too high _hotwater warm air _direct vent wall heater could be a good choice _central depends on the size of the job and existing duct work |
HVAC Old Timer
Trade: HVAC
"the purpose of a site like this is to get the opinions of other pros. I am not an HVAC pro....so I thought I'd try to learn from your expertise."
OK then, as a sun room has a LOT of glass, which is very cold in cold climates, from experience, I wouldn't blow 90F air around in a poorly insulated room with much glass to stay in for any time long, as would a heat pump. I never enjoy being in a hotel room for long with their heat pumps, as they are noisy when in the same room and the blower never stops. I've had many customers who just couldn't stand living in the breeze from a heat pump. I'd pick something that gave off some radiation, like baseboard or radiant panels to make up for cold surfaces. But then, I'm spoiled by my hot water baseboard heat that I installed after the heat pump I had. A PTAC is a cheap, quick solution though. |
Trade: HVAC
Sounds like a small room to me, so a seperate unit is the only way to go. That being said, if gas was available it would be the least expensive to heat with. If not then heat pump with electric back up. Enough said. Why go through the work of running duct work out there off a system that may be at it's limits now?
#13 | |
Trade: HVAC
HVAC Old Timer
Trade: HVAC
Right about the hot water. From no clues in the question; but about PTAC, there is a higher likelihood of electric, which even though electric is a high rate, might not allow a nifty gas direct vent baseboard unit. If just electric is allowable, I'd pick the radiant panels on the lower wall below the windows, if that is the situation.
Insufficient information and no way to peek, it's a guess. This is Kevin75's statement quoted to answer it. No win there; just looks contentious to every other reader. ///"the purpose of a site like this is to get the opinions of other pros. I am not an HVAC pro....so I thought I'd try to learn from your expertise." So why have the "heat pro" tag line and say you are one ? /// Last edited by HeatPro; 12-19-2007 at 08:59 PM. |
Newbie
Is there any sort of small unit that would be able to be installed in the crawl space below the sunroom/addition? There's about 3-4' of crawl space below the floor joists. It would be easy enough to run duct work if it wasn't served from the main house.
HVAC Old Timer
Trade: HVAC
Is there gas available; if so, you could use a package that contains a gas heater and AC? If not, an electric heat/cool unit can be used running ductwork under the floor. There are small separate heating/cooling units for either gas or electric or both that can be done that way.
http://www.bryant.com/products/packaged/index.shtml |
Trade: hvac tech
I'm pretty sure there's a different site for smart ass egomaniacs ...
#18 |
HVAC Old Timer
Trade: HVAC
I'm sure there is hf05; there are plenty of places on the web for 'flamers' to vent hate against individuals for a thrill as you are doing, instead of actually answering the question on the thread about what is the better heating and cooling. So where is your answer to the question instead of using the old political means of flattering yourself through useless wise cracks?
