Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 12-19-2007, 01:27 AM   #1
Trade: General Contracting
PSI problem
I have an oil furnace in a 3 story row home... It pushes hot water through baseboards with 3/4 copper supply and return... Everything works perfect on the first and second floor.. all my heaters heat up great but on the 3rd floor i have no heat... i checked for stop valves along the way to the boiler and found none... My temp meter is at 120 and my psi meter is at about 15... do i not have enough pressure to get the hot water up to the 3rd floor??? if so how do i change the psi?? and isnt it dangerous if my psi is to high??? HELP!!!!
nick114920 is offline   Reply With Quote
Old 12-19-2007, 09:28 AM   #2
HVAC Old Timer
HeatPro's Avatar
Trade: HVAC
Too high psi is dangerous. The qualification is that it is dangerous if it is over the pressure on the relief valve; which means that the relief valve is bad. However, as most relief valves on residential boilers ar 30 psig, yours is well below the limit.
Follow the instructions here for setting the pressure:
http://www.heatpro.us/purgeairtree/d...6F851F932.html
HeatPro is offline   Reply With Quote
Old 12-19-2007, 01:56 PM   #3
bled all radiators and the ones on the 3rd floor release a little air but still no water
Old 12-19-2007, 02:44 PM   #4
HVAC Old Timer
HeatPro's Avatar
Trade: HVAC
You didn't raise the pressure til there is 4 lbs water pressure at the highest point of the system? That is the point in the reference.
Old 12-19-2007, 08:34 PM   #5
Trade: HVAC
Raise the pressure up to 20 psi and see if you get water with some pressure behind it.
BigMikeB is offline   Reply With Quote
Old 12-21-2007, 12:07 PM   #6
Bjd
Trade:
Do you have zone valves or circulators?
BJD
Bjd is offline   Reply With Quote
Moisture Problem Milhaus Commercial Construction 6 12-26-2007 02:47 PM
Toilet problem Mike Finley Plumbing 5 11-06-2007 10:21 AM
Heat Exchanger Problem with Hayward Pool Heater jtc1062 HVAC 2 10-22-2007 09:13 PM
Well problem paintr56 Plumbing 10 02-09-2007 09:20 AM
Strange Fly Problem johnnymac Plumbing 4 09-07-2006 01:30 PM
