Hi Guys,
I'm hoping someone here can give some ideas as to what's wrong as I am at my wits end.
First off this information pertains to an Air Quest (International Comfort Prouducts Corp.) Model# NTGMO75EGA3 90 plus efficiency forced air furnace. The unit was installed new about 6 years ago and up until recently has worked perfectly. Last winter it started behaving strangely. At first the draft inducer motor would come on and go off several times before completing ignition and going through a normal cycle. Later that day it got to the point where all you could hear was what sounded like a relay on the fan control board rapidly opening and closing (about every second) , and this would make the whole housing vibrate, then it quit operating all together. It was believed by a local tech that the fan control board was bad. After repalcement it worked fine for a little over a month and started exibiting the same symptons, However later on the ignitor issue ceased and the draft inducer motor was still cycling on and off before operating properly. Still later that day, when I returned home from work, back it was working fine! It then started the same sequence except that at one point the burner fired and stayed lit for a minute or 2 without the blower motor running, and then it shut down and starting the relay noise, so I turned main power off and on a few times and it went back to normal operation again. A friend of mine who works for Siemens Building Technologies looked at it and installed a back up relay for the blower motor seemed to take care of the problem for the remainder of last winter. It worked fine this winter until last week when it started acting up again. I'm now convinced this only served as a band aid! Here are the current symptoms: Started out with a normal cycle, but blower motor would not come on, burner would stay llit until it reached limit I assume, and shut off. After turning power off and back on, would somtimes operate for a full cycle and other times the blower motor would cut out prematurely and after turning the stadt all the way down to kill the burner, the relay noise would begin again. And last night it did the weirdest thing, started the normal cycle, blower failed to come on. so I turned the stadt all the way down, shortly after doing this the blower motor came on by itself! I noticed often times if I leave the power off for the night, it will run for fine for two or three cycles before acting up again. This morning, however, the blower fan cut out after about ten minutes of operation. Could this newest control board be going bad already or is there an underlying problem contibuting to this? Sorry this is so long, but I felt a detailed history would help. One more thing, this furnace has no diagnostic indicator lights. This is a very frustrating and expensive situation! Thanks in advance for your time!
