Trade: Plumbing&Heating
Pressure Switch On A Coleman
I have a Coleman furnace not in a mobile home, the fault code says pressure switch stuck open, describe switch and location please.
I believe it's the round switch with the hose attached to it. |
Trade: Squirrel Handler
Re: Pressure Switch On A Coleman
It looks like a Coleman pressure switch, it has terminals and a nipple or two and it's located inside the furnace.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
HVAC CONTRACTOR
Trade: HVAC
Yes, it may well be the static switch, remove the hose from both ends then hold it up to your ear lisen to see if there is a vacumm. make sure that pitot tube at the combustion fan is not pluged. If not just test continuity at each safety swicth till you find the open one.
WARNING:If you don't know then don't do,so those who do know what you did not know,don't end up undoing what you did,so it can be done right! |
| Multiple fixtures on switch loop | KenHaynes | Electrical | 2 | 12-05-2007 03:15 PM |
| Lennox Pressure Switch Trouble? | Glock23 | HVAC | 1 | 01-03-2007 10:25 PM |
| Irrigation pump pressure switch | mdshunk | Landscaping | 10 | 12-04-2006 09:39 PM |
| Draft inducer vs. pressure switch vs.? | arctic trooper | HVAC | 3 | 03-15-2005 08:29 AM |
