Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 01-01-2007, 10:06 AM   #1
Frankawitz's Avatar
Trade: Plastering, Drywall, Painting, Woodworking, Stucco, refinishing woodwork
Is it possible to repair P.E.X tubing?
Hey guys was wanting to know is there any way to repair PEX tubing? Here's what I did I have my kitchen floor all done with the PEX tubing and like a dumb ass I took and used mortar to fill in around the tubing, well the mortar failed and started to pop off the dura rock I used in between the tubing. anyways I used a putty knife to scrape the mortar up off the floor, well as I did this I hit the tubing and put a good cut into the tubing. Now it just happens to be in the middle of the run. so to replace it would mean I have to remove the whole kitchen floor, then relay all new tubing. So do you think I could used epoxy on the PEX tubing to seal the cut. Any help would be appericated. Thanks
Frankawitz is offline   Reply With Quote
Old 01-01-2007, 11:38 AM   #2
Doc
Old and Tired
Trade: Remodeling and home services
I don see how epoxy could work. once cured it has no flexiblity but the flex would still try to expand/contract = repair failure. Maybe a repair coupling of some type?
Surely someone around here will know or come up with something.
There is a huge range of knowledge and experience here.
Those who cannot remember the past are condemned to repeat it.
Doc is offline   Reply With Quote
Old 01-01-2007, 01:34 PM   #3
Trade: Jack of all trades/Master of none!
Yes
Yes, you can repair it. First you need to know what brand/manufacturer the pex is and then get the correct repair coupling for it. or you can just use a coupling barb and crimp rings.
Viper is offline   Reply With Quote
Old 01-09-2007, 06:26 AM   #4
Frankawitz's Avatar
Viper, Thanks I will contact the supplier I purchased my system from and see if they have what I need to make the repair. I appericate your help thanks
Frank
Old 01-10-2007, 02:32 PM   #5
Trade: Electrical and Plumbing Contractor www.LMNelectrical.com
Send a message via Yahoo to terrynistler
Be very very careful most couplers will raise the finish floor level and you will need the tools to crimp them as well. I would also redo pressure check.
terrynistler is offline   Reply With Quote
Foundation repair (New business) Help! crosshair66 Business 10 05-18-2008 08:19 AM
wood shingles repair? fast pasquale Remodeling 3 04-09-2007 09:18 PM
After repair Repair dayspring Masonry 4 03-18-2007 01:24 PM
How much can putty repair? JohnDucan Painting & Finish Work 9 01-11-2007 08:36 PM
Chicago Home Repair License? Grumpy Contractor Licensing 24 09-14-2006 11:48 PM
