Poll Question? How Many New HVAC Units Do You Adjust Charge On?
Old 04-10-2006, 07:45 PM   #1
workman's Avatar
Trade: general contractor
Here is a poll question. On new installed HVAC units how many do you have to adjust the charge on? Percentage! Come on now...lets be honest!
workman is offline
Old 04-10-2006, 10:00 PM   #2
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
Re: Poll Question? How Many New HVAC Units Do You Adjust Charge On?
About 15%. Most of that is due to longer linesets. Once in awhile, a short one.
HVAC Doc is offline
Old 04-28-2006, 08:17 AM   #3
hf05's Avatar
Trade: hvac tech
probably 20% install a lot of 410 puron units and find alot of these usually under from factory
hf05 is offline
Old 05-04-2006, 08:56 PM   #4
proud to be a tech.
Jeff_at_HuxL.T.'s Avatar
Trade: hvac/r
intstalled a new Trane unit today, lost all respect for their residential units. Charge was too low, no knockouts for the new gas line on the furnace, and the lines frome the acoil weren't plugged, but had brazed on caps that would NOT come off, so I had to cut them off!
Jeff_at_HuxL.T. is offline
Old 05-11-2006, 11:26 PM   #5
Aceinstaller's Avatar
Trade: sub-contractor
I superheat all of my new installations and add freon as needed in all of my installations.
If Im installing a unit in the winter, I will weigh in my freon according to the line set chart given with the manufacturers spec sheet.
Ace
Aceinstaller is offline
Old 07-09-2008, 08:22 PM   #6
HVAC Tech, NATE certified
Verbal's Avatar
Trade: Hvac technician. Boehmer Heating
our company mandates all new installs must be superheat/subcool balanced. we even do cold weather charging. if you ever want to know how to do it, search the thread in here on it. it might be a pain but it cuts down on the "it doesnt seem to be cooling just right" calls at 2am.
Verbal is offline
Old 07-11-2008, 04:02 PM   #7
coolmen's Avatar
Trade: hvac
You cant cut corners with the 410a. Every single condenser set gets checked and adjusted per subcool/MFG.
coolmen is offline
Old 07-25-2008, 01:15 PM   #8
Rod L's Avatar
Trade: HVAC tech-installer
i would have to agree with the HVAC Doc
Rod L is offline
Old 07-26-2008, 08:53 PM   #9
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
For me its more like 90%, the ones with longer linesets than factory charged for and the ones that are build up. I dont do any residential.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Quick Question on how you would charge... DNJ6357 Framing 1 07-06-2007 02:15 AM
HVAC Question MikeT HVAC 7 07-08-2006 10:24 AM
Using two units to replace one Atricaudatus HVAC 5 04-02-2006 10:51 PM
