Please Help...Goodman GMP Gas Furnace Problem
Old 10-27-2004, 02:55 PM   #1
River's Avatar
Our heater is not working (and it's getting cold)...
Basically, when the thermostat calls for heat, nothing happens. The indicator light is blinking rapidly and continuously...This (according to the indicator chart) means that I should try reversing the primary and secondary wires (at the transformer) to reverse the polarity. I have tried this but the thing still won't work.
I am reading 26.7 Volts off of the secondary. The schematic calls for 24 VAC. Could the 2.7 VAC make a difference? Should I just replace the transformer?
I just replaced the control board a year and a half ago...so I'm hoping that's not it...but tell me if you think it is.
ANY suggestions would be greatly appreciated! (also, does a 24 VAC transformer actually put out 26.5 V??? ...you know, like how they call them 2x4s but they really aren't 2" by 4" anymore)
River is offline
Old 10-27-2004, 05:21 PM   #2
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
Re: Please Help...Goodman GMP Gas Furnace Problem
If you are wanting to reverse polarity, you DON'T want to mix the primary and secondary leads with each other. Yes you can have that much voltage coming out on a 24v. transformer. My recommendation is call a professional in before you end up having to replace more than a board.
HVAC Doc is offline
Old 10-27-2004, 08:08 PM   #3
Richard Johnson's Avatar
Send a message via ICQ to Richard Johnson Send a message via MSN to Richard Johnson
I agree, you should call a qualifed service technician.
Richard Johnson
VP-Operations
ClimateMaster Mechanical, Inc.
Richard Johnson is offline
Another Goodman GMP-075-3 problem rhinoguy HVAC 12 12-05-2010 06:52 AM
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-29-2008 12:05 AM
Goodman GMT045-3 Blower problem GaryStevens HVAC 2 02-23-2007 12:17 AM
carrier gas furnace problem mjm0073 HVAC 4 01-30-2007 11:34 AM
goodman furnace roll out switch problem mme HVAC 9 02-10-2004 08:20 PM
