Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 04-29-2009, 02:41 PM   #1
pex radiant floor heating - heat transfer
Does anyone know the heat transfer from 5/8" pex to concrete for different delta T's between glycol and concrete?
Guido48 is offline   Reply With Quote
Old 05-02-2009, 06:36 AM   #2
Trade: HVAC
Varies with how much glycol(10, 20, 30, 40, or 50%).
What your center is.
And what you GPM is.
EG:
30% glycol/water solution at 120°F entering temp, and 110°F leaving temp(10° delta).
50 BTUs per sq ft, 12" OC equals .01056GPM per foot of tubing.
So 200' of tubing would have a flow rate of 2.112GPM.
20 BTUs per sq ft, 12" OC equals .00422GPM per foot of tubing.
So 200' of tubing would have a flow rate of .844GPM.
Both of the above BTU examples are at 10° delta.
You need to know more then just delta to calculate BTUs.
beenthere is offline   Reply With Quote
Ever heard of electric radiant floor heat under slab? IHI HVAC 10 02-27-2009 05:32 PM
heat pump jdager HVAC 2 01-31-2009 04:17 PM
Radiant heat pipe install question im4snow HVAC 4 01-13-2009 08:02 PM
Tile over hydronic radiant heat angus242 Ceramic & Stone Tile 18 10-30-2008 08:44 AM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
