Pellet Stoves
Old 11-06-2017, 10:52 PM   #1
VinylHanger's Avatar
Rewards Points: 7,616
Pellet Stoves
Not sure where to put this, but I figured I'd start here.
We have gone through 3 really cold winters since we lived in this house. We have a few baseboard heaters, but they don't really do the trick.
I think a pellet stove is our best option considering placement, cost of install kit and pellets are cheap. Wood insert is out because I would need to repair the chimney, and that isn't an option for the next few years.
Who here uses a pellet stove? Any suggestions on models or brands?
I am thinking around 1,500 bucks or so would be doable this winter. House is around 1,700 square feet of living space, though the back bedroom will still be heated with baseboard.
One that has caught my eye is the Pleasant Hearth 1,750 sq. ft. model. Any thoughts on this one? Is the lack of thermostat a big deal?
https://www.lowes.com/pd/Pleasant-He...-Stove/3772643
Is it better to go with a larger stove in the 2,200 sq. ft. range, or stick to a proper 1,750 sq. ft. model?
VinylHanger is online now
Old 11-06-2017, 11:52 PM   #2
hdavis's Avatar
Rewards Points: 9,115
Re: Pellet Stoves
Harmon.
Thermostat is pretty nice, but it does wear out the igniter. Pellet stoves need routine cleaning, and you Can't use cheap pellets, they give feed problems.
hdavis is online now
VinylHanger (11-07-2017)
Old 11-07-2017, 12:16 AM   #3
hdavis's Avatar
Re: Pellet Stoves
Smaller is better. High fire is cleaner and more efficient.
Old 11-07-2017, 05:36 AM   #4
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 432
Re: Pellet Stoves
Check out hearth.com they have a pretty good forum over there.
Sent from my SM-G900V using Tapatalk
mrcat is online now
The Following User Says Thank You to mrcat For This Useful Post:
Old 11-07-2017, 06:01 AM   #5
rrk's Avatar
Rewards Points: 1,906
Re: Pellet Stoves
I have 2 of them, have not used them in a while because oil is so cheap now. 1 has a thermostat one does not, thermostats cause issues if the burn pot is not kept very clean. Not all pellets are the same, once you find the ones that work best with your stove stick with them.
Much easier to clean than a fireplace and only takes 1 bag of pellets a day.
I have a Quadra Fire and an Enviro, I like them both.
rrk is offline
Old 11-07-2017, 06:34 AM   #6
larry228's Avatar
Trade: residential remodeling
Rewards Points: 115
Re: Pellet Stoves
I don't think the thermostat should be optional. This is the beauty of the pellet stove- it turns off before the room gets hot enough to roast the cat, turns back on before it gets too cold
I have an 8 year old quadra fire, haven't had ignitor problem yet. Pellet stoves are high maintenance, always seems to be something to tweak or repair, lots of cleaning required.
Great heat, pretty convenient after the years supply of fuel is carried in
larry228 is offline
The Following User Says Thank You to larry228 For This Useful Post:
hdavis (11-07-2017)
Old 11-07-2017, 07:28 AM   #7
hdavis's Avatar
Re: Pellet Stoves
A lot of pellet stoves have reliability issues, particularly with the feed mechanism. Harmon doesn't. Do your annual checks at the start of the heating season, and run it as your primary heat source all winter without problems, just clean it on schedule.
Pellet stoves Paul B General Discussion 6 11-02-2013 12:44 PM
Pellet Furnaces mrmike HVAC 5 04-20-2010 06:11 AM
For those who use pellet stoves ..... user50444 HVAC 2 11-02-2009 10:13 PM
Wood pellet shortage Jason Whipple General Discussion 2 10-20-2008 08:06 PM
pellet stoves??? POOLMANinCT HVAC 41 12-13-2007 11:32 PM
