Pellet Stove
Old 02-20-2008, 07:05 AM   #1
orson's Avatar
Trade: Kitchen & Bath
Pellet Stove
Anyone here ever heard of tying a pellet stove in to a house's ducting to act as the primary furnace? I need to replace our oil furnace soon and I'm curious if this is ever done.
www.rubycon.us
Ruby Construction LLC
Lancaster Kitchen Remodeling
Lancaster Bathroom Remodeling
orson is offline
Old 02-20-2008, 08:19 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Pellet Stove
Yes, I did it at my cabin, when I am not there it uses the gas furnace set at 45 degrees, when we are there I switch to the corn burner.
KillerToiletSpider is offline
Old 02-20-2008, 09:26 PM   #3
siberian's Avatar
Trade: Property mngt
Re: Pellet Stove
We instaled a St. Croix this year. It is working fairly well.
Problems-
Hopper doesnt hold as much as they said
Little harder to get used to than a regular pellet ( can burn a lot of pellets when its not set right, as well as a lot more cleaning)
Advantage.
Hooked right into the heat ducts
works very well unless temp drops below 20-30, at 0 to 15 degrees a great drop...I say advantage because I may just have to lay out new duct work(hope)
Cleaning is the one thing that I dont feel they stress enough. When temps drop below 30 it needs cleaned alot. If this is the only heat source that is a problem. Over all it has saved some money. Not counting the time it takes to go get the pellets and store them, load them , and clean it.
siberian is offline
Wall around a wood stove guyute65045 Carpentry 5 12-14-2007 03:06 AM
pellet stoves??? POOLMANinCT HVAC 41 12-14-2007 12:32 AM
info on stove co. boman47k Off Topic (Non Trade) 1 07-02-2007 03:34 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 11:47 AM
Wood stove and furnace exaust Glasshousebltr HVAC 1 10-24-2005 09:45 AM
