Payne Electric Furnace
Old 10-26-2005, 03:28 AM   #1
ChrisinAr's Avatar
Trade: mechanic
I have a Payne electric furnace that comes on for about 30 seconds then cuts off for about a minute then back on and off. I had this problem back in feb. of this year and it was fixed under my home owners warranty. Now It is doing the same thing again, any suggestions on what it is?
Thanks Chris
ChrisinAr is offline
Old 10-26-2005, 06:17 AM   #2
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
Re: Payne Electric Furnace
Did you get a receipt with the repair? If so, look at what they "fixed" and start there. Sounds like a thermal cut-off is tripping and resetting itself or a sequencer/relay with a bad coil not holding. Remember, it is 240v. inside there so be careful what you touch and where you put your meter at.
HVAC Doc is offline
Quality of Payne furnace ??? Home Pro HVAC 45 03-30-2010 10:10 PM
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-29-2008 12:05 AM
Power vent vs. electric water heater. osborn Plumbing 8 03-02-2007 11:04 AM
Forced Air Furnace w/Air Heat Pump Backup mahleumon HVAC 1 03-14-2006 10:15 PM
Consolidated Diesel Electric Genset thecrose12 Electrical 0 03-08-2004 04:34 PM
