good, then reference your DB and RH on the chart and see that it falls with in your comfort range.
a percentage of your coil is designed for latent heat removal, and quite frankly, in my opinion the latent heat that is removed is the most important. at least in my area where humdity is a real comfort issue. i used to recommend and set my own tstat to 72, but i allow it to fluctuate between 78 and 75 constantly with a t8112 5-2 tstat. i am actually more comfortable at these temps with the RH kept at or below 50% and i see a considerable drop in my elect. bill. granted we had a mild summer so far.
hey the dryer the better, in order to maintain vapor in the air a great deal of heat energy is needed, latent heat. so the dryer the air is the less btu's in the air.
