Outside Roof Furnace Noise/hot
Old 09-16-2010, 04:12 PM   #1
nicmac's Avatar
Trade: kitchens
This house was purchased and it has no basement, just a crawlspace. The previous homeowner was apparantly an HVAC guy and used a rooftop furnace but placed it beside the house and hooked it up. There is some venting under the house that the vents are blocked because hardwood floor was put in the house and installed over some vents that we never opened. The house has been like this now for about a year and a half. The furnace last year was really loud when on and now today its smelling like burnt dust in the house. When her husband went to check it, it was crazy hot under the house and the vent leading to the house was too hot to touch. He lifted the top off the furnace and a big gust of HOT heat came up (after furnace had been off for 20 minutes).
Whats up with the furnace? Is it gonna blow up or anything catch fire? Is that possible?
nicmac is offline
Old 09-16-2010, 04:44 PM   #2
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,112
Re: Outside Roof Furnace Noise/hot
If the safeties fail it could.
Tell them to call a HVAC service company.
beenthere is offline
Old 09-23-2010, 10:06 PM   #3
Dr Heat
Dr Heat's Avatar
Trade: hvac
Rewards Points: 306
Soon!
Dr Heat is offline
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 22 01-05-2013 05:42 PM
Patio roof venting BoulderBuilder Roofing 9 01-01-2013 12:52 PM
rubber roof over rolled asphalt ? ? btownpa Roofing 2 03-06-2009 02:03 PM
Frost on underside of roof sheathing ApexCS Remodeling 5 01-15-2009 12:55 PM
What Is The List Of Every Line Item Possible For Roof Replacemts From Insurance Cos.? Ed the Roofer Roofing 15 08-31-2008 03:19 AM
