Outdoor Wood Boiler Question
Old 11-02-2007, 04:34 PM   #1
RopeaGoat
Guest
RopeaGoat's Avatar
Posts: n/a
Good Evening Fellas,
I just looked at an outdoor wood boiler piggybacked through a plate exchanger to an older (30 years give or take a decade) steam boiler that's only used for forced hot water currently. The complaint is the wood boiler is not keeping up with the domestic hot water. All the heat zones go through two tankless coils and the DHW comes off the bottom of the steam boiler. I think the tankless coils are scaled (sp?) or rusted up and the heat from the outside boiler is not heating the water in the steam boiler enough. Either that or the four other zones are using too much heat first. My thought is to add another plate exchanger solely for DHW and reconfigure the other zones to hopefull bypass or replace the old steam unit. Any thoughts or comments would be appreciated.
Old 11-02-2007, 04:38 PM   #2
tinner666
Guest
tinner666's Avatar
Posts: n/a
Re: Outdoor Wood Boiler Question
WHy not ask these guys? http://www.centralboiler.com/
Old 11-02-2007, 08:45 PM   #3
RopeaGoat
Guest
RopeaGoat's Avatar
Posts: n/a
Contacted Central Boiler and they suggest abandoning the old steam job and adding a larger heat exchanger into the mix. However the Home Owner still wants an oil backup in case they go away or run out of wood. Thanks for the site though.
Later
Outdoor Wood Boiler Question RopeaGoat Plumbing 12 11-16-2007 05:43 AM
boiler plumbing question 72chevy4x4 HVAC 2 05-06-2007 08:26 PM
